Convertible enhancements GM SB # 92-260-10
Old 12-14-2009, 09:38 AM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I thought some of you would find this helpful...
It is the Convertible Enhancements - Noise, seat belt trim, operating and leak issues Service Bulletin.
It applies to all ASC convertibles.
NOTE: the figures on page 8 are now included in the file...
File Type: pdf
Old 12-14-2009, 10:30 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Re: Convertible enhancements GM SB # 92-260-10
Thanks John! I do have an issue with the solenoid releasing on the left side. In the spring i will have to look into doing the fix that is refered to in the bulletin.
Old 12-14-2009, 11:19 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I'll have to check this out later too
I have the same solenoid issue
-jason
Old 12-14-2009, 03:58 PM
okfoz's Avatar
I just noticed that I am missing some figures... so I will have to get to that tomorrow.
John
Old 12-15-2009, 06:44 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Thanks for the information. There is another way to eliminate the rattles and noises from our tops though - PUT THEM DOWN! Its the only way to drive these cars.
Old 02-22-2010, 12:37 PM
viktorvon's Avatar
Car: 1992 Z28 Convertible
Engine: 5.0L 305
Transmission: Turbo-Hydramatic 700R4
might be random, but my passenger seat squeaks when no one is in it
anyone know how to fix?
Old 02-22-2010, 03:36 PM
bluegrassjh's Avatar
Car: 91 IROC Conv.
Thanks..very helpful
Old 02-28-2010, 11:12 AM
oramac z28's Avatar
Car: 1992 Z28 Black Vert aka ORAMAC
Transmission: Stock manuel 5 spd
Axle/Gears: stock
Hey anybody know where I can get a new switch for the lid release ? Mine still works but the black plastic prongs that hold it in place have somehow broke off causing the switch to dangle by the wires--sucks. Thanks !
Old 02-28-2010, 11:40 AM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
You can use a hatch release switch - exactly the same except for the image on it... I've got a brand new one if you are interested...
Old 03-05-2010, 08:49 PM
oramac z28's Avatar
Axle/Gears: stock
How much ?
Old 07-20-2010, 08:57 PM
posiaxle's Avatar
i was at the local pic n pull and up pops this 91 camaro conv this car had these tube steel originally gold cad trailing arms they had a seat belt type fabric about 10 inches long and bolted to the inner well so when the car is airborn or just lifted up yhe rear end does not drop . this car also had a tubular panhard bar. oh btw it was installed with rtw bolts like factory stuff. i bagged this stuff. i have an 89 iroc conv. just supposing that maybe it was an updated asc conversion stuff never seen anything like it.any thoughts
Old 07-27-2010, 01:12 PM
okfoz's Avatar
posiaxle
AFAIK ASC did not update any of the suspension... it sounds like an aftermarket change to me... I know that they use things like that on race cars so that when they pit and jack it up the car they can access the tires faster... The straps specifically is what I am referring to...
John
Old 08-02-2010, 06:00 PM
jeffdelguercio's Avatar
Car: 79 bird w 403, 92formula conv. da b
Engine: 403
Transmission: r4
Axle/Gears: limited slip
absolutely! try to explain that at 90 the rain doesn't even come into the car!!! 92 Form. Conv. Love it! By any chance do you know where to get the plastic piece that goes handle to handle???
Old 09-22-2010, 08:55 PM
noel8877's Avatar
_________________________________
Soundproofing
Sound Proofing
Old 08-14-2011, 01:20 PM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
Great info!!! will come in handy on my '89 IROC-Z, as my top make a lot of noise.
Old 01-30-2012, 07:31 PM
ridecool's Avatar
Car: 89 Iroc Convertible
Axle/Gears: 373 posi
I have an 89 Iroc convertible, just changed the top and I am having trouble with the rear latch locking. Any help on working this out.
loud91rs
Camaros Wanted
03-28-2016 04:13 PM
Thirdgen89GTA
11-26-2015 11:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
bjpotter
10-04-2015 07:48 PM
tcarlos13
Interior Parts Wanted
09-28-2015 06:31 PM
Quick Reply: Convertible enhancements GM SB # 92-260-10
