I'm in trouble... 92 Z03 Z28 Vert
#101
COTM Editor
Re: I'm in trouble... 92 Z03 Z28 Vert
Got the intake gaskets & water pump buttoned up yesterday... Thing was nasty inside.
Couple pics from the underside now that I finally got in on a lift... No rust!!! Lost of undercoating I'm gonna wash and degrease this baby later, so some clean (hopefully) pics to follow.
My 8 month old Braxton helped me the whole time. His first intake job
#102
COTM Editor
Well I haven't really driven the car since I bought, so now that the intake gaskets, spark plugs, O2, and all the fluids/filters are serviced I took it out at lunch...
Service engine light comes on and immediately falls on its face. Pull into grocery store as its trying to stall out, cutting off a Mustang and stalls. Will only make 1500 rpms with WOT, and puffing out black fuel smoke. Attempt to limp back to shop at 1500 rpms WOT, and suddenly kicks in and spins the tires, and SES light is out!!! Scan it to find TPS signal voltage low... Inspect sensor to find that the connector with the broken clip I thought would be ok... loose. At least I made it back!
#105
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I hear ya, when you push these things they seem to weigh a metric ton
How are you doing with the wildfire situation out by you?
#106
COTM Editor
The fire just miles from my shop is now at 100% containment... still burning, but not spread, so the air has been better. The one in CO. Springs was so horrible Obummer came out to see the damage. It getting better, but no fireworks this year
#110
COTM Editor
I'm pretty damn happy and proud to have them both. I'm hoping I can show them side by side late in the summer.
#111
COTM Editor
So after my fun yesterday at lunch I played with it after work. Was running warm (235*) with fans running and a 180* new t-stat, so inspected the radiator and /ac condensor fins...
PLUGGED!!!! Looks like a cat was living in there... YUCK!
We have an attachment on out pressure washer specifically for this, and cleaned them out perfectly
#112
COTM Editor
I also cleaned my washer fluid bottle... I had forgotten about this amazing plastic cleaner that I found when clean the underhood of the 91 years ago
Brake fluid... yep I said Brake fluid. We all know it will eat the paint off metal surfaces. Well years ago there was yellow paint pen "maintenance records" painted on bottles fan shroud and alternator. I used a rag soaked with brake fluid to remove the paint with out damaging the plastic.
I used this same method of a brake fluid soaked rag and also a brake fluid soaked Scotch bright pad to clean the bottle. I am very happy with the results. nearly new condition of the plastic.
beforeBottle was not in horrible shape as you can see, but had severe stains, and paint? overspray on it.
after Much better even though the purple washer fluid doesn't really help show the contrast. It looks great! I have a new correct cap at home
I'm gonna try it on the coolant bottle and just see what happens even though I have a replacement coming from Hawks.
#114
COTM Editor
I have another tip/trick to show you guys, but I wanna be able to show some good before and after pics. Stay tuned LOL!
#115
COTM Editor
Well Hawks put their convertible top trim panel on sale... so another part on the pile!
http://www.ebay.com/itm/89-92-Firebi...item3f1947d50a
#116
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
So I just noticed your sig picture had two cars and I had to dig up this thread, congrats on the new project.. I want something new to wrench on too!!
#117
Engine: Cammed 6.0L LSX
It's coming along very nicely!
#118
COTM Editor
If I could just get more time to work on it I would really be making progress
#119
COTM Editor
So not sure if anyone noticed the missing muffler, so I had a flow pro muffler and slash cut tips off the old 92 parts car welded on... It sounded so horrible, but I can honestly say that that was the first mistake I have made with this project... its ugly I load some pics later.
#120
COTM Editor
I don't like it...
#121
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
well tips are easy to change... what are you thinking about now?
btw, I don't think it's ugly. a little generic maybe, but not ugly
#122
COTM Editor
I thought I would be able to "cheap" out on the exhaust and re-use the muffler/tailpipes from the parts car... guess not
#123
COTM Editor
So on my lunch break today I installed the "old" bottle from my 91 into the vert. I think it looks pretty good from what it did a month ago. Still need to clean/treat the rubber & plastics.
I think this used bottle looks alot more at home in there than if I had chosen to install the new one in here, instead of the 92.
#125
COTM Editor
Thanks man! Trying to do something to everyday. Replaced the oil pressure sender... it now reads pressure all the time
Got my Hawks vert top panel tonight... anyone buy one of these? There is no mounting screw holes in mine. Is there supposed to be?
#126
Nice buy!
#128
COTM Editor
Thanks man! I'm pretty happy with how things are coming out. Still spending more money on little stuff that I really didn't want too, but it will make the fit/finish of the end result that much better.
#129
COTM Editor
Well I got had to replace a sensor and decided to snap a picture with exhaust on, and pressure washed undercarriage. I bead blasted the trans pan to remove spray paint jobby that someone did.
So its cleaner, but the pressure washed off some of the undercoating in areas where it was put on light... Should I try and remove the rest of it for aesthetics, or leave it?
Oh one more job to put on the to-do list... Why is my carpet turning green? Dammit!!!!
#131
COTM Editor
Rust is not a big deal here in CO, like CA, and AZ... Its too dry for severe rot.
I'm planning on selling the car off at some point, so keeping prospective buyers thoughts/opinions on the cars condition is important. I think that it would look best removed, but is it worth the PITA to get it all off and make it look good, or would anyone give a shift?
#132
id prefer to buy a car that has been or still is undercoated, because i drive mine and live on the east coast, altho 2 of my camaros wer not undercoated and wer stilll rust free.. so idk, if its a show car then NO undercoating, i like the clean painted undersides, but for a driver definably yest
#133
COTM Editor
I'm torn on the undercoating... and looked up the procedure on the heater core... Not fun!
#135
COTM Editor
I'm not excited to do it. First of my thirdgens to ever need it. Guess this one was the only one that was given up on, and parked.
#136
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
man the heater core is NO FUN at all to replace. Only job on the camaro that I've started and had to walk away from to cool off.
#137
1 Post
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Car is looking great! I'd re-undercoat the car myself. Keep up the good work!
#138
COTM Editor
Cleaning trick - I found the most amazing CHEAP carpet cleaner ever... My wife spilled her box of nail polish and broke two bottles of red nail polish in our brand new carpet after our re-model. Huge puddle of red paint in my hallway. We tried everything to get it out... Nail polish remover, acetone, brake cleaner, vinegar etc... Nothing would remove it, and now we have a large pink stain. My little sister says "Shaving cream will take it out"... One can of Barbasol regular ol foamy shaving cream, and a clean white cotton rag, and you would never know there was a stain.
I thought... if it will take paint out of carpet I bet it would just clean carpet well... So I used 1 can of Barbasol Pacific breeze (cheapest at the store) and scrub brush and proceeded to scrub the shaving cream into the areas with noticeable staining/dirtyness. I then used warm soapy water and a scrub brush for the entire carpet and mats, finishing off with shop vac to suck all the water out. There is a stain under the passenger seat I didn't do, cause I thought you'll never see it, but it turned out so good I think I need to go back and "fix" it.
Before:
After:
Before:
After:
#140
wow that is a neat try, i gota try that on my sport coupe, if only i new that 2 months ago i wouldnt have bought new carpet for my iroc :/
#142
COTM Editor
I'm happy to share with anyone willing to read my thread
The aftermarket carpet is such low quality. I'm very happy with how nice this came out. I actually would like to install this carpet in my 91 to replace the ACC carpet the now when side to side with factory appears to be turning green... too much work haha!
I was amazed it took finger nail polish out. Hope it helps someone else.
#143
COTM Editor
Got a used wiper stalk of a member, and installed that today during my lunch break. Its not perfect, but man is it better!
Also got my hatch release switch (new GM) popped in. Looks too good in there
#144
Transmission: World Class T-5
Axle/Gears: BW 3.45
Before:
After:
Before:
After:
Thanks for the tip!
#146
Dude, I thought this was going to be a joke, I have been around car for close to 40 years and never heard this ever. The results speak volumes, I guess I need to put a can of Foammy in my detail kit.
#147
COTM Editor
No doubt! I was more amazed it took paint out my house carpet that acetone wouldn't touch! The used camaro carpet is a super bonus!
#149
1 Post
Now if only you had a miracle cure for the carpet turning green! I've got the same problem. LOL!
#150
COTM Editor
Thanks man! I don't really care for that look, but I had the setup and it didn't cost me anything to get a muffler on it.
I'm thinking about trying the GM cooling system sealer tablets... I will let you know if they work.
