88 camaro iroc z convertible top size?
Car: 88 Camaro Iroc Z COnvertible
I have an 88 iroc convertible that needs a top, I know where I'm going to order it but I need to know if it take the 50" wide or the 51" wide. This wouldn't be a problem for me to measure but it doesn't have a top on it at all right now. So what I'm asking is, is if anybody knows what size that my car calls for or how to measure it without the top.
Thanks for the help,
Bobby
Bobby
Car: 1988 iroc convertible
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3.23 posi
Re: 88 camaro iroc z convertible top size?
Hi did you ever figure this out? I'm having a similar issue and wondering if I can put a 90 complete top assembly on my 88.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe that 1988 had the narrower top
I also believe that you can put a complete top from a 1990 onto a 1988... Lon would know better, but I believe the mounting holes are the same. There was only one mounting change, that was in 1992 when they went from 2 bolts to 3 bolts behind the door IIRC...
1992 Trans Am
05-10-2023 07:19 PM
Linson
08-21-2015 02:12 PM
