top assembly bolt sheared off HELP!
One of the pivot bolts that holds the skeleton and mechanical assembly of the top frame on my 89 has sheared off. It is one of the bolts with a torx head, it starts out large and then has a smaller diameter that threads into one of the arms. It will have to be easy outed that's no big deal. What is a big deal is chevy says the bolt is discontinued. I have never even seen a vert in the junkyards around here. I can take a pic of it if necessary I am wondering if anyone else has experienced this. Of course also, the top will not go up correctly now.
Car: 89 Iroc Convertible
Re: top assembly bolt sheared off HELP!
I have a few of those torx head pivot bolts if you need one
Engine: 4++,350 & 305 CIs
I have a 89 top assy that I use for parts. If you need anything else let me know.
Post a pic of its location if you can.
I sent you another PM.
I have the bolt in hand.Im checking on the rear speaker grille too
Car: 1991 Z28 Convertible
Engine: 5.0 V8
Transmission: auto
One of my bolts just sheared off and I am in the same position. Does anyone have any more of these bolts?
Car: 1989 RS Black Vert
Engine: 305 TBI
Axle/Gears: 2:7some thing
need to remove bolt with washer .
Do you have the right one
The lower bolt is sheared off to
Hello: This is { I rock 88 }
I just pick up a 89 RS vert.
The top has two of bolts that have sheared off on the driver side.
Do you have any more of the bolts.
Engine: 5.0 V8
Transmission: auto
I ended up getting one of these "shoulder" bolts with an Allen head from Fastenal. Quite affordable and I got 2 extras incase they were to ever snap again.
Engine: 305 TBI
Did you get a part number or do you have the part number.
That would help all us vert Drivers some in owning a vert.
I rock 88
I rock 88
Engine: 305 TBI
Hello:
Do you still have the bolts I need.
Will you part with them?
Thanks I rock 88
Thanks I rock 88
Engine: 305 TBI
Hello: This is I rock 88
Do you still have the top bolts in the photo.
I need 2 bolts and the washers that go with the bolt.
Thanks for you time.
I have a few of those torx pivot bolts left over
Engine: 305 TBI
OK:
I need 2 bolts and the 4 washers .
You can contact me buy phone at 1-480-246-1059.
Or by email.
Thanks I rock 88
Or by email.
Thanks I rock 88
Engine: 305 TBI
Here are the 2 location of the bolts .
Here is a photo of the bolts that I need. {2}
I also need the 2 shoulder washers per bolt also.
No photo of the washer / do you need a photo of the washer to.
Engine: 5.0 V8
Transmission: auto
I ended up finding a good replacement to the torx bolts. I went to Fastenal and got some allen head shoulder bolts at a fraction of the cost of the GM bolts. Less than $2 a piece, I think.
Engine: 305 TBI
Hello my82roc
Do you have still have any of the Torx bolts.
I'm still looking for 2 bolts and the 4 washers.
Thanks I rock 88
Thanks I rock 88
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
mhatfield 14
10-24-2015 07:48 AM
hectre13
08-26-2015 08:17 AM
BurlyChev
08-22-2015 01:52 PM
