trunk pull down wiring
Old 09-05-2014, 09:37 PM
Gecz28's Avatar
Car: 88 iroc vert
im looking for so help with my pull down. quick overview...im doing the full 4th swap, ls1, dash ect all wiring. so im looking to find out which pull down wires go where. theres is only 3 but would like to know where there go or what they connect to ie power ground ect
can any of you guys help??
Old 09-05-2014, 09:53 PM
Joe Tag's Avatar
Re: trunk pull down wiring
On the 3rd gen motor assembly you have a blue wire which is a constant hot, a black which is ground and a white which goes to the cargo area light(not used on some cars). Ground on your motor should already be screwed to the body, just need to find the constant hot on the 4th gen wiring and run the white to the cargo light if you have one.
Edit: You'll have to run the same constant hot to the other wire of the cargo light. It grounds through the latch switch on the white wire.
Old 09-05-2014, 10:11 PM
Gecz28's Avatar
Car: 88 iroc vert
ok nice thanks joe.
are the wires on the trunk side for the 3rd brake light?
Old 09-05-2014, 10:14 PM
Joe Tag's Avatar
The metal contacts to the hatch? Yes. And YW.
Ghettobird52
12-29-2023 08:23 AM
Infested
05-22-2018 11:56 PM
AmorgetRS
Convertibles
08-31-2015 11:55 AM
Bert87
08-23-2015 03:50 PM
mx127
08-10-2015 08:13 AM
Quick Reply: trunk pull down wiring
