Purple Haze!
Old 01-24-2016, 04:58 PM
  #201
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Purple Haze!
Great looking car Chaz, you have put some good work in that one and it shows. How many Purple Haze Z28 converts made? Pardon me if you have already shared the production numbers I didn't see them in the thread. Prolly not too many is my guess.
Old 01-24-2016, 06:24 PM
  #202
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Purple Haze!
Thanks! 84 PHM Z28 'verts were made.
Old 02-12-2016, 04:51 PM
  #203
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
I used BDNBLK's trick of repurposing a passenger seat cover for the driver's side. I took the seat as well as a passenger seat cover to a shop. They resectioned a portion of the existing seat cover, the panel on the outside of the right bolsters onto the passenger cover to create a driver's side.
Driver's seat before:
And after:
Old 02-15-2016, 08:48 PM
  #204
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Re: Purple Haze!
Looking nice.
Old 02-15-2016, 11:41 PM
  #205
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
Thanks!
Old 02-16-2016, 06:22 AM
  #206
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Purple Haze!
That does look nice and makes a great use of all of the good passenger seats.
Old 02-16-2016, 08:59 AM
  #207
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
Thanks. The other thing for me is that it's an original GM seat cover which matches the passenger side perfectly.
Old 03-25-2016, 02:45 PM
  #208
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
Thanks to 1MeanZ, I was able to locate a near perfect dash pad from a parted car.
Old.
New dash pad, cleaned, detailed and installed.
Old 03-25-2016, 02:57 PM
  #209
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
Re: Purple Haze!
Originally Posted by chazman
A couple of questions.
What's this going on with the steering wheel and how do I fix it?
my 92 has same wheel I tried heating it but didn't work
Old 03-25-2016, 03:02 PM
  #210
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
I was able to kind of manipulate it and press it back in.
YMMV.
Old 03-25-2016, 03:03 PM
  #211
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
As far as the old pad, I think I'm going to use it as a guinea pig, and see if I can repair it. I love that kind of crap.
Old 03-25-2016, 03:10 PM
  #212
82tarecaro's Avatar
Re: Purple Haze!
You are setting yourself up for disappointment. Trust me. Save yourself the heartache and toss it. It will crack again. You will be angry.
Old 03-25-2016, 04:14 PM
  #213
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
Just for fun Vince, just for fun.
Old 03-25-2016, 07:27 PM
  #214
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Purple Haze!
IMO/FWIW, the vinyl shrinks over time and when it does finally split, the open edges along the crack curl upwards. I'm assuming that every time the vinyl is cut back, it will just curl up again. Anyways, to me, that seems to be the reason they're more difficult to repair without removing the entire top.
Old 03-25-2016, 08:03 PM
  #215
82tarecaro's Avatar
Re: Purple Haze!
The problem I had was, even though the cracks were minor, and I drilled the ends of them to stop them from spreading, the cracks came back. I used a flexible plastic bumper epoxy, retextured, repainted, etc. It looked great. But the cracks came back. I did like Chuck did and found a decent used pad. Hopefully it holds up. I had a lot of time invested into that pad. I still wake up at night screaming when I think about that crack coming back.
Old 03-25-2016, 09:46 PM
  #216
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Purple Haze!
Nice OE dash pad is sweet Chazman and is an instant makeover for the car.
Old 03-25-2016, 10:09 PM
  #217
Scorpner's Avatar
Engine: V6, V8
Re: Purple Haze!
Oh. That's a good idea and I would have done the same. Wonder if the cracks are stress related then?
Old 03-26-2016, 12:27 AM
  #218
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
It really is! I can't stop looking at it today!
Next week I'm having the front bumper cover repainted and some other touch ups, and probably look at selling it shortly thereafter, in order to make room for the next one.
Old 03-26-2016, 07:36 AM
  #219
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Purple Haze!
YMMV.
When you say you manipulate it, did you use something to persuade it or just force it back? Did it stay or did you use some kinda glue to hold it? I have tried to force mine back and it just won't go. I was thinking of maybe using a 2x4 for leverage.
Old 03-26-2016, 08:46 AM
  #220
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
I can't remember if I used my fingers or a tool, but I didn't use much force.
A 2x4 will definitely apply enough force to get 'er done.
Old 04-05-2016, 09:10 PM
  #221
chazman's Avatar
Axle/Gears: BW 3.45
Re: Purple Haze!
Just letting you guys know in advance that I'm having the front bumper cover repainted this week and putting the car on eBay thereafter.
If anyone has any interest in the car before that, please send me a PM.
Thanks.
Hotrodboba400
12-10-2019 07:07 PM
3rd gen money
10-11-2019 09:57 PM
Elephantismo
02-13-2019 12:51 AM
Cleotiz
09-16-2015 08:02 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Purple Haze!
