1991 Firebird/Trans Am Convert owners inside.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am trying to compile the different production figures for colors and interiors for 1991 Firebird Convertibles. I have almost everything, but I am missing some information on some colors.
IF YOU HAVE ONE OF THESE FACTORY COLORS ON YOUR 1991 FIREBIRD SEND ME THE VIN OR POST IT HERE PLEASE
PLEASE Do not waste my time or your time if you do not have one of these colors on a 1991 CONVERTIBLE. Also indicate which color you have. Thanks
98U - BRIGHT BLUE METALLIC
87U - Gray Metallic
75U - Brilliant Red Metallic
82 Interior trim color (GRAY) Leather or Cloth is ok.
87U - Gray Metallic
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: 1991 Firebird/Trans Am Convert owners inside.
My Brilliant Red Metallic TA convertible is VIN . Hope it helps you. Do you also want the RPO codes or a copy of the SPID?
edit:
WEll that stinks, it did not come back with a hit...
I am trying to get a comprehensive list of most of the RPO's & the production figures from compnine for 1991 Firebird convertibles. I have the Camaro Coupe and Vert, and the Firebird Coupe, but I do not have the Firebird Vert.
I know it would only have 95%, but it is better than nothing.
Thank you anyways.
Edit II
You missed the 2... Got it thanks again, when I am done I will post what I find here.
You have about 1 of 121 Red Metallic Firebirds (includes Trans Am's and Firebirds) and also being a manual transmission, with the LB9, I would probably guess it is quite rare.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Sorry about the missing VIN digit. Sometimes my keyboard has a mind of its own!
I got the same info back in 2003 from J. Mattison - he said it was 1 of 120 1991 TA's with the LB9 and 5-speed combination. I have never seen another in shows around here in NW Florida but a few '91 and '92 automatics in different colors have appeared. I go over to the Cruizin' the Coast show every fall in Mississippi and have not seen one there either. I would enter mine but they have a rule that the cars must be 1989 or older.
Good luck collecting the data. I hope others have replied to you via PM's to get things going.
someone972
08-30-2015 12:52 AM
theshackle
08-23-2015 03:49 PM
