Trunk rear plastic cover
Old 08-18-2015, 01:33 AM
AmorgetRS's Avatar
My 1992 Firebird Convertible is missing the cover that goes at the very rear of the trunk that covers the hatch mechanism. Since it has the slam latch I wasn't sure what the correct piece was that goes there. I have spare t-top ones from pull down coupes, but it doesn't seem right since it has a large square opening and a giant bump for the pull down mechanism. Did they use the panels from early non-pull down cars?
Old 08-24-2015, 01:53 PM
AmorgetRS's Avatar
Re: Trunk rear plastic cover
Nobody?
Old 08-24-2015, 03:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The 2(92s) I have seen (1 being mine) use the big plastic part and the molded fabric on the sides.
Old 08-24-2015, 05:57 PM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
they have 2 different size panels, they both look similar, but one has a larger hump in the middle for the hatch mechanism, that is for the electric hatch, the push down hatch is the smaller one, refer to my cars album for a closer look at the push down kind
Old 08-24-2015, 06:10 PM
AmorgetRS's Avatar
But which one was used in 1992 Convertibles? Since sometime around 1987 the electric pull down became standard they would have stopped producing the manual hatch ones. I would guess they wouldn't do a run of them for the Verts with their manual latch in late 91 and 92, but I could be wrong.
That is disappointing if they used the same pull down piece as the power pull down models. Seems like a bunch (in terms of Thirdgen trunk space) of wasted space. Is it a hard top or t-top one? Does it have a light? If so, what tripped it turning on/off?
Old 08-25-2015, 08:07 AM
TTOP350's Avatar
My 89 formula 350 vert has the auto pulldown latch so its standard for all the cars that yr.
My 92 TA vert has a "slam closed decklid" as I call it and it has the standard plastic piece covering it as did the othe late 92 I saw.
Old 08-25-2015, 11:20 AM
AmorgetRS's Avatar
Sorry if I am being obtuse, but on the 92 Vert, when you say standard do you mean the standard pull down one or the slam hatch one?
Old 08-25-2015, 02:05 PM
TTOP350's Avatar
It has the slam closed decklid.
The normal interior plastic panel covers it in the trunk, just like the earlier cars with the auto pulldown.
Old 08-31-2015, 11:55 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, the 91-92 'vert uses the same plastic trim panel from the '86-'92 coupes. Only for the piece that covers the latch. They probably could have reverted to the older '82-'85 slam latch slimmer plastic trim panels, but they were no longer in production.
The sides were molded carpeting (unlike the '87-'90 verts which used modified coupe side trim panels).
Lon
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
Fronzizzle
03-18-2019 08:29 PM
I'llrocya
02-02-2016 11:43 PM
86White_T/A305
08-17-2015 12:16 AM
Quick Reply: Trunk rear plastic cover
