interior lights wont shut off.
Car: 92 z28 convertible
Engine: 305 tpi
Axle/Gears: 2.73 to1
hey fellas. the lights on both sides of my back seat wont turn off. it drains the battery and leaves the car dead. just wondering if there is a manual switch for them . or is it myhead light switch that needs replacing?
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: interior lights wont shut off.
You can turn on or off the interior lights by the switch... Could be a bad door switch or the headlight switch...
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
you have lights at your back seats ... i would like to see a pic ... are they factory? ... i was going to put some in the back of my gta, just not sure what ones i was going to get ... if they are factory i will look for a set of those ... also, do all the other inside lights work with the dimmer ... if so i would start looking for another hidden switch
Engine: 305 tpi
It is a convertible thing, since there was no dome light.
jstanfi1
07-01-2016 11:53 PM
angelr
11-05-2015 07:29 PM
HP52TA
Exterior Parts Wanted
11-02-2015 09:08 AM
