Help with 88 Convertible top DFW Area
1 Post
Car: 89 GTA/90 Iroc Vert
Engine: 5.7/5.0L
Transmission: 700R4 x 2
Axle/Gears: 3.27/2.73
Re: Help with 88 Convertible top DFW Area
Good luck with that man ... Camaro verts are notorious for the rattles.
If you figure it out please share.
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Mine doesn't rattle. I'd go through each little section and tighten or replace the bolts/nuts of it and oil/grease it lightly. A tight top won't rattle. Also a tired suspension can compound the issue.
1Aauto
Sponsored Vendors
09-18-2017 12:33 PM
