glass or plastic?
Car: 1992 convertible RS
Axle/Gears: Stock
glass or plastic?
I am replacing the top on my 1992 RS. should I spring for the glass window or stay with the plastic.???
Axle/Gears: Stock
Re: glass or plastic?
So, will the glass fit with the seat belt towers? That is what I have.
1 Post
Car: 91 Convertible
Engine: Stock 305
I do too! For anyone considering, the things I have had with glass/ cloth top is your top will be a bit heavier to maneuver. And you'll need to move your rear seats forward to clear the glass then back. Those are minor compared to having the great look.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I changed mine out about 12 years ago after 13 years with the original. Time to do it again and I will definitely go with the glass. A little inconvenient but the visibility is well worth it.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Yes, it was garaged for the first 10 years and about half the time in the next ten when I moved from Atlanta to NW Florida. Never any road salt, snow or ice to worry about in either location. I always hand wash the car and am very careful about dust and other abrasives. Still, after about 10 years the plastic windows have gotten enough UV exposure and small scratches that has diminished the visibility. The material on the top has gotten some wear areas from lowering and raising it so maybe in a year or so, I'll replace it again (and get one with a glass window).
