Above Window Weatherstripping + Another Question
Can anyone point me in the right direction for the weatherstripping on top of the windows on my 91 Camaro vert? Specifically, I'm after the passenger side of the attached file.
Additionally, is there a difference between an after-market replacement and the OEM part? I'm assuming it glues on.
My other question is in regard to the top. A small section of the top fabric has become unglued right above the top storage hatch weatherstripping. Any tips on how to correct this? Specifically, is there a glue or technique that I should use?
Re: Above Window Weatherstripping + Another Question
I would believe you need something such as this: http://www.1aauto.com/1987-92-chevy-...FQgOaQodBiYNnQ
Metro Moulded is actually very close to me - I picked up a rear bow seal a few years ago, and it fit fine.
I cant help on the glue issue, I had my top installed professionally, as it looked to be quite a bit of work, and didn't want to screw it up. I would venture that an automotive upholstery shop would be able to fix it for you for a reasonable amount if its just the glue that came undone.
1 Post
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
That weather stripping just slides into a channel. Slide it out one end and slide the new one back in. Easy
89irocz355
26
09-12-2016 01:28 PM
