If you own an '84, '85 or '86>>
#102
Car: Whatever I can get to start.
Engine: broke 305 H.O. (now a N.O.)
Re: If you own an '84, '85 or '86>>
84 350 HO - Came with 1 electric fan and one carburetor fan (which was a dealer install directed by GM for all 84's late in the year that had not been sold yet, supposedly to prevent vapor lock after the car shuts off because of the high temp the engine runs at). Thermostat is 195 degrees, electric fan is set to turn on at 236 degrees. Electric fan turns off after the car drops back to 200 when the car is moving again instead of sitting in traffic and the air dam puches air up to the radiator. These parts worked perfectly until the motor threw a rod at 85,000 mileson original engine last year. The carb fan always seemed useless because there was never any gas left in the carb to start the car up and i had to let the electric choke really run, and pump up a lot of gas to start. Maybe it would have been worse without the carb fan, but I doubt it. The only time I had an actual overheating (the car runs really hot to begin with) was when my radiator broke.
#103
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
You would be perfect if you had the 160 degree in. I went through this last summer. Broke the bolt in the intake so I used it as an excuse to upgrade the intake...haha...the cooler you get these cars, especially in the summer the better off you are.
#104
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
#105
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
85 Z28,single belt driven fan.
#106
#108
Location: Great Smoky Mountains, Bryson City North Carolina
1 Post
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
1986 T/A WS6, 305 TPI, 700R4, 9 BOLT 3:27 DIFF, SINGLE ELECTRIC FAN.
#109
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
1986 Trans Am, built 9/85 LG4
electric single fan
electric single fan
#110
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
85 berlinetta lg4 4-barrel belt driven with a/c
#113
Car: 1985 Camaro Iroc-Z
Engine: 5.0 TPI
Axle/Gears: 2.73 posi
1985 Iroc-Z TPI. One cooling fan, and it runs ALL the time
#116
Car: 85 Camaro,05 Escape
Engine: v6 2.8 ltr,3.0 ltr
Transmission: m5
1985 berlinetta 1 elec. fan v6 2.8 lt
#120
Car: 1986 camaro sport coupe
Engine: 2.8 v6 MPFI
Transmission: LB8
Axle/Gears: 2HH 3.42:1
i have a 1986 sport coupe v6 MPFI factory. it has a belt driven fan
#122
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
1986 LG4, AT, single electric fan, Norwood, Oh built.
83,000mi, Edelbrock 3701 intake, Stant HD 180 degree thermostat, Edelbrock aluminum water pump, stock radiator.... seldom climbs over 180 degrees on the highway, reaches 220 in slow traffic.
#124
On Probation
84 Z 305 ho auto. has a/c..........Electric fan and somebody cobbled a switch and wiring to turn on the fan at will. They did remove the sensor and wiring so I am unable to return the e-fan to automatic operation.......No overheating issues tho.
BUT somebody that doesn't know will not turn on the fan while driving and overheat the car. My only solution was to hunt up a OE belt driven fan and shroud assembly.
There is enough clearance to keep the e-fan in place and install the factory shroud/fan set up over it so I will have DOUBLE the air flow over the radiator if necessary.
Then I won't have to worry if mom rides my Z down to the grocery store and forgets to turn on the e-fan and it won't overheat and cook the motor!!!!!!!!!!!!!!!
#126
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
85 IROC (donor car of mine) 5.0 H.O. L69 I think, 4bbl carb, 700r4 trans. It has both the belt driven and one elecric fan on the condenser side. I think its all original looking at it.
#130
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
85 Z28 T-top w/TPI 305 single electric fan, alt on pass side W/rib belt, a/c on drivers side w/v-belt.
#133
Car: 84 Z-28, original owner
Engine: 305HO,+.030, mild cam
Transmission: TH700R4
Axle/Gears: 3.08, highway gearing, posi
84 Z-28, all original, 305HO, one electric fan
#137
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
The air dam is a must, ya I had one down there but if its bent back just a little its not deflecting the air into the radiator. I made some metal brackets to help support it back to the foward position, but you cant make them to strong. Here's what my radiator looks like with 2 puller and one pusher fans on a griffin aluminum radiator. No cooling problems after I fixed the air dam on my 400 small block,
#138
Car: 86 irock z28
Engine: 305tpi gt 350 though then ls
Axle/Gears: lol no clue new to cars
i got a 305 86 tpi irock z 28 to um like i have a after market fan in it witch works grate and a air dame and ducks frome a 91 rs camaro and a decent radatior new pump nunen spesiol but i wana k can i do or add any thing for more cooling power cas like on hot days if im geten on it it begines to heat up
#139
Engine: 406
What cant really understand you
#140
Car: 1986 Z28 Camaro
Engine: 5.7L 350
#143
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
86 camaro sports coupe, 2.8 with v belts and single electric fan
#144
Car: 91 rs3.1, 87 iroc 305 6 speed
Just bought an 87 iroc w/ 305 tpi 5 speed. It is missing a module(?) That resides on the passenger side, next to the radiator. One connector goes to the fans, the other I dunno. Help, please.
#146
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
1986 2.8L V6 Sport Coup 5 Speed Manual Transmission 1 Electric cooling fan.
#147
#148
The 3rd gen electric fans are activated by relays. On the dual, or heavy duty fans, the primary, driver's side fan is activated by the ECM, the secondary fan is controlled by a Fan Temp Switch which is in the passenger side cylinder head, between #6 & 8 spark plugs. The relays are generally located close to the battery, on the radiator support.
My 87, VIN code F, has dual, heavy duty electric cooling fans.
#149
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
1984 2.8 Belt Driven fan
#150
I need basic info on factory coolant fans. Please go to:
https://www.thirdgen.org/techbb2/sho...hreadid=150575
and post the year of your car, what your original engine is and whether it came with a belt-driven or electric coolant fan. Thanks.
Willie
Willie
86 IROC 305 vin F 1 fan. Now has a 350, but still got the 1 fan (electric).
