Willie's updated Total Fan Control
#51
give me an hour or 2
#52
arg! thought i had saved as a pdf, i did print it out though, do you have a decent printer? if so post that you do and i will take pictures of the printouts, as im not in a very "up to date country" right now so no scanner for me to scan to you, unless anyone else here has this saved into some other kinda of format. let me know.! will be glad to help you if i can!!!!
at least for this project (on 2 of my f-bodies) i was smart enough to remember to take alot of pictures of before and after!
#53
found a big piece of it in tech section though if need more just ask me
GM F-Body Electric Coolant Fan Specifications and Modifications
Jason|Xoxide Mar 31 2006 - 4:16pm By William Weissman (tplsz87@cs.com)
Overview
General Motors engineered these cars to run HOT!! The primary coolant fan does not engage until 222° or higher (depending on application) and the secondary coolant fan until 243° or higher. It's been shown that at these high temperatures, air and fuel burn more completely and therefore produce less hydrocarbons. However, these temperatures severely reduce engine life and kill performance. So why not just install a lower temperature thermostat and call it done? Simply because a lower temperature thermostat only opens sooner. In stop-and-go traffic, the engine's temperature will continue to rise unless there is sufficient air flow to the radiator. Assuming the A/C is turned off, have you noticed that on the open road, the temperature is acceptable, but when you hit city traffic, it climbs to astronomical levels?
Objective
The fan turn-on temperature must also be lowered. The true ideal system would incorporate a simple, straightforward design without disabling GM's system. I will explain this later.
So let's say that you install a 160° thermostat and a switch that engages the fan at 176° (or so). It seems like the ideal situation -- until the first cold day. Then, the engine will never reach full operating temperature because the fan is running -- when you don't want it to. The heater will only work marginally, at best. Of course, you can change your thermostat and fan switch twice per year, but do you really want to do that? How about a typical fall or spring day when it's cold in the morning and warm in the afternoon. What do you do then? Is there a practical solution?
First, let's examine how GM designed their coolant fan turn-on system. Then I will explain how it can be modified in the "Recommendations" section.
Note: For those F-bodies with only one coolant fan, the following information referred as "primary coolant fan" is applicable. In the "Recommendations" section, there is a sub-heading specifically for single fan cars.
Primary Coolant Fan Turn-On System
Factory Circuit Operation
On TPI engines, the primary fan is controlled by the ECM and A/C head pressure. The ECM grounds the coolant fan circuit when the coolant temperature sensor indicates the temperature is greater than 222° or when the A/C head pressure is greater than 232 psi and the vehicle speed is less than 35 or 40 mph (depending on application). When this circuit is grounded, the fan relay is energized and voltage is applied to the fan.
Secondary Coolant Fan Turn-On System
On some applications, the secondary fan is controlled by the ECM, A/C pressure switch and a temperature sensor, similar to the primary fan. On other applications, the ECM is bypassed and only a temperature sensor is used.
Aftermarket Products
Here is a sampling of products that will modify the factory settings. There are others, but they essentially accomplish the same thing.
Hypertech makes a fan switch (Part No. 4026). Available through Summit Racing (800) 230-3030 for about $45.
Features:
Features:
Features:
Features:
Features:
Overview
We know that heat shortens the life expectancy of engines. The temperature that GM operates their engines is acceptable for lower emissions, but a killer for performance and longevity. I found it imperative to lower the operating temperature.
Through five years of research, primarily trial and error, I believe that I have designed a system with the most versatility. I call this my "Total Fan Control" system.
For most performance enthusiasts, the approach is to lower the operating temperature by using a 160° thermostat and either running the fan constantly or using a turn-on switch at approximately 170° to 175°. This is acceptable and fully functional, except in the winter months or during emissions testing. If we follow this approach, the engine never reaches full operating temperature in the winter months and the heater works marginally at best. I suppose you could change to a 180° or higher thermostat and change the fan operation back to stock, if you're willing to do this twice per year. I do not find this solution acceptable. Also, think about the ambient temperature on a typical spring or fall day. In the morning and night, it's cold. In the afternoon, it's rather warm. On these days, it would be ideal to use the 160° thermostat and modified fan control in the afternoon and a 180° with factory fan control on those cold mornings and nights. If there were a way to run "Summer Mode" and be able to change to "Winter Mode" at the flip of a switch -- that would be ideal. This was my goal -- and I've accomplished it.
In analyzing all the products on the market, I came to the conclusion that none of them would meet all my criteria. It would take a combination of products and a little ingenuity on my part. In analyzing the factory coolant fan wiring diagrams, I decided that I would not disable GM's wiring scheme in any way for two reasons:
(1) For those who live in states with a yearly emissions check, wouldn't it be nice to revert back to the factory settings at the flip of a switch?
(2) By supplementing the factory system, there are actually two systems working independently of each other, the factory system and the Total Fan Control system. If the Total Fan Control system were to fail (in four years, it never has failed me), the factory settings, which have not been disabled, will engage the fan(s).
The information I share with you is a culmination of my research. I think you will agree that this is the best and most versatile system available today.
Thermostat
Of the numerous experts on tuned port injection engines, Greg Carroll of Carroll Supercharging Company and Myron Cottrell of TPI Specialties stand out. Greg Carroll states that 160° is too cold for these engines. He suggests a 170° thermostat. Myron Cottrell says, "We have found that 170° is a better temperature for all-around driving. The computer in your car is designed to provide a correct fuel mixture at whatever temperature the motor is controlled. The 170° thermostat provides the best compromise between power, economy and wear." I have found that with a 170° thermostat, I do not need to change between a 160° for summer and a 180° for winter, but that I can use it year-round.
I used to use the 160°/180° thermostats in combination with my coolant fan system and a stock chip for about four years with no problems. I did grow tired of having to change it twice per year, though. I knew of the 170° thermostat, but to the best of my knowledge, TPI Specialties was the only source. For $10, it was not worth it. Last year, I discovered the AC Delco part number for this thermostat (about $4) and have been using it ever since. On those cold mornings, the heater actually works. It never really worked effectively with the 160° thermostat (luke warm at best). And as for those hot days, think of this; with a 160° thermostat, what do you think your normal operating temperature is with the A/C off? I'm willing to bet that it's not between 160° and 170°. It's probably around 170° to 185°. Even with a 160° thermostat and both fans running, the engine will only cool to around 170° to 185°. Therefore in the summer, it's irrelevant whether the thermostat is a 160° or a 170°.
Before installing the thermostat, modify it by drilling four 0.150 inch diameter holes in the thermostat body. The holes allow a constant restricted flow of coolant through the engine which prevents hot pockets from forming. Although GM does not list a 170° thermostat in their application charts, it is available through any GM dealership. Order AC Delco part number 10220957.
Primary Coolant Fan - Dual Fans
Now that I've decided to use the 170° thermostat, which fan switch should I use?
I chose the Hayden thermal switch for a variety of reasons. This switch allows for an additional path to ground (Option #1a outlined below). The Hypertech switch does not because it replaces the stock switch. This additional path to ground affords many other options that aren't available with the Hypertech switch.
For example, by installing a toggle switch in series with my new circuit, I can turn off this circuit. This is important on those cold winter days when you want your engine temperature to be warmer and only the second fan is needed. The Hypertech switch allows no options as with the Hayden switch. Once the Hypertech switch is installed, your stuck with it - your fan will turn on at 176° and your heater won't work.
I must mention that the Hayden kit contains several parts; a relay, the thermal switch, and a fuse holder. Only the thermal switch is used for the primary fan circuit. The relay may be used on the secondary fan circuit as outlined later.
The wiring diagram is simple and straightforward. The optimum location to insert the brass switch is about three inches below the top radiator hose. This allows the switch to "see" the coolant temperature as it enters the top of the radiator where it is hottest.
Option #1a
What I have done is added an in-line toggle switch to this circuit. By turning the switch off, control of the first fan is accomplished the way GM wanted it. By turning it on, the fan will turn on when coolant temperature reaches 185° (fixed turn-on point of the brass switch) and turns off at 170°. Imagine that -- off at 170° -- and we're running a 170° thermostat. It couldn't be more perfect. I call this switch "Auto 1".
Option #1b
In addition, if you want the option of turning on the primary fan at the flick of a switch, it's as simple as adding another parallel circuit (spliced into the same location -- the green/white wire at the coolant fan relay). Essentially, this circuit is used as a "manual override" and I call this switch "Fan 1".
Option #1c
An fan indicator LED can be wired as confirmation that the fan is on. This is also shown in the wiring diagram. Secondary Coolant Fan - Dual Fans
I use the Derale adjustable relay for my secondary fan turn-on. For the same reasons outlined above, I did not select the Hypertech switch. I did not select the Hayden adjustable switch (I used to use it until I found the Derale unit) because it does not have an LED mounted on the unit, nor does it continue to run when the ignition is turned off on those hot summer days. By allowing the fan to run after shutdown (usually only 5 minutes or so), it helps to prevent the coolant from continuing to heat up. If you start your car back up within 10 to 20 minutes of shutdown, the temperature is higher than before shutdown. The Derale unit helps to prevent this, the Hayden does not.
According to the Derale installation instructions, the fan wires, (+) and (-) are connected to the unit. This necessitates disabling the factory circuits. I do not recommend this. Instead, what I've done is connect the fan wires, (+) and (-) to a SPDT relay (explained in detail later). The SPDT relay then energizes the fan by grounding a parallel circuit installed between the coolant fan relay and ground (just like the circuit I added to the primary fan circuit). The Derale unit wired in this manner allows full function of the factory setup.
Option #2a
What I have done is added an in-line toggle switch to this circuit, similar to Option #1a. By turning the switch off, control of the first fan is accomplished the way GM wanted it. By turning it on, the fan will turn on when coolant temperature reaches 195° (adjustable). I call this switch "Auto 2".
Option #2b
In addition, if you want the option of turning on the secondary fan at the flick of a switch, it's as simple as connecting the A/C turn-on wire on the Derale unit to a toggle switch. Why not wire the A/C turn-on to the A/C compressor? The factory setup will turn on the fan when A/C pressure exceeds 232 psi. Because my circuit does not disable the factory setup, the A/C will still engage. Therefore, we can connect the A/C turn-on circuit to a switch that acts as a "manual override". I call this switch "Fan 2".
I occasionally drag race my car. In between runs, I want to cool the engine as much as possible. This is when I turn on "Fan 1" and "Fan 2". In the event that the thermostatically controlled switch fails (it's never happened to me) and/or the Derale unit fails, then you can turn on either fan at the flick of the switch.
Option #2c
A "fan on" indicator LED can be wired as confirmation that the fan is on. This is also shown in the wiring diagram.
note - wouldnt let me post all in one reply second will follow this one -
Overview
Objective
Features:
- Replaces the factory switch.
- Fan turn-on at 176°, off at 166°.
Features:
- Replaces factory switch.
- Fan turn-on at 200°, off at 185°.
Features:
- Thermal switch mounted in radiator.
- Fan turn-on at 185° and off at 170°.
- Can be wired to augment factory switch, not replace it.
Features:
- Adjustable turn-on from 160° to 210°.
- Can be turned on automatically when AC is engaged.
- Can be manually turned on with a dash-mounted switch.
Features:
- Adjustable turn-on from 140° to 260°.
- Adjustable turn-off from 2° to 20° below turn-on temperature.
- Can be turned on automatically when A/C is engaged.
- Can be manually turned on with a dash-mounted switch. LED indicator.
- If running when ignition is turned off, the fan continues to run until turn-off temperature is reached.
Overview
Thermostat
Option #1a
Option #1b
Option #1c
Option #2a
Option #2b
Option #2c
#54
Primary Coolant Fan - Single Fan
Now that I've decided to use the 170° thermostat, which switch should I use?
I recommend either the Hayden thermal switch or the Derale adjustable switch. Your personal preference will dictate which is right for your application.
Both switchs allow for an additional path to ground (Option #3a outlined below). The Hypertech switch does not because it replaces the stock switch. This additional path to ground affords many other options that aren't available with the Hypertech switch. Once the Hypertech switch is installed, your stuck with it - your fan will turn on at 176° and your heater won't work.
Let's examine the Hayden and Derale switches in detail.
The Hayden thermal switch closes the circuit at 185° and opens at 170°. These points are fixed and non-adjustable. The optimum location to insert the brass switch is about three inches below the top radiator hose. This allows the switch to "see" the coolant temperature as it enters the top of the radiator where it is hottest.
The Derale unit can be adjusted to turn on from 140° to 260°. It can also be adjusted to turn off from 2° to 20° below the turn-on setting. This unit also has an "on" LED, and most importantly, if it is running when the ignition is turned off, it will continue to run until the preset turn-off temperature is reached. By allowing the fan to run (usually only 5 minutes or so) after shutdown, it helps to prevent the coolant from continuing to heat up. If you start your car back up within 10 to 20 minutes of shutdown, the temperature is higher than before shutdown. The Derale unit helps to prevent this, the Hayden does not.
Option #3a
What I have done is added an in-line toggle switch to this circuit. By turning the switch off, control of the first fan is accomplished the way GM wanted it. By turning it on, the Hayden or Derale switch will be armed. I call this switch "Auto".
Option #3b
In addition, if you want the option of turning on the fan at the flick of a switch, it's as simple as adding another parallel circuit. Essentially, this circuit is used as a "manual override" and I call this switch "Fan".
Option #3c
Summary - Dual Fans
Modes of Operation
I have addressed these problems stated in the Objective section -- and have solved it. It does not take just one aftermarket product, but a combination of two products installed with a modified wiring scheme. What I have designed is a system that will run the engine as cool as possible in the summer, and at the flip of a switch, warm enough in the winter to allow the heater to function effectively. Also, how about that dreaded time each year -- emissions check -- when we all wish our cars would magically return to the stock temperature. My system is so versatile that this can also be accomplished at the flip of another switch. All this without having to change the thermostat.
Oh, Those Hot Summer Nights.
When the ambient temperature is high, turn on "Auto 1" and "Auto 2". This will engage the primary fan at 185° and the secondary fan at 195° (can be adjusted to your preference).
Brrrrrr!!! Those Icy Cold Days.
When the ambient temperature is low, turn on "Auto 2" only. This will engage the secondary fan at 195° (can be adjusted) and the primary fan at the factory setting (about 222° depending on application). In the winter, I have found that the secondary fan is sufficient.
Wanna run???
At any time, one or both fans can be manually turned on by switching "Fan 1" and/or "Fan 2".
Yes, Mr. EPA, my car IS stock!!
At any time, both fans can be returned to factory specifications by turning off all switches.
Summary - Single Fan
Modes of Operation
I have addressed these problems stated in the Objective section -- and have solved it. It takes one aftermarket product installed with a modified wiring scheme. What I have designed is a system that will run the engine as cool as possible in the summer, and at the flip of a switch, warm enough in the winter to allow the heater to function effectively. Also, how about that dreaded time each year -- emissions check --when we all wish our cars would magically return to the stock temperature. My system is so versatile that this can also be accomplished at the flip of another switch. All this without having to change the thermostat.
When the ambient temperature is high, turn on "Auto". This will engage the primary fan at 185° (Hayden) or at your pre-selected temperature on the Derale unit.
When the ambient temperature is low, turn off "Auto". In the winter, I have found that the fan never turns on when in factory configuration - it just doesn't get warm enough.
Wanna run???
At any time, the fan can be manually turned on by switching "Fan".
At any time, the fan turn-on temperature can be returned to factory specifications by turning off both switches.
Additional Part
SPDT relay
Required with secondary fan or single fan (adjustable switch only)
This is a 30-amp single-pole, double-throw relay. In addition to the relay that's supplied with the Hayden kit (Part No. 3652) with the thermal switch, there are two others available. AutoZone stocks a Blazer SPDT relay and costs about $4, but it does not come with a wiring harness. Bosch's SPDT relay costs $9 and it comes with a wiring harness. I prefer the Bosch because there is a noticeable difference in quality. In addition, GM uses Bosch relays in their cars. Unfortunately, I cannot seem to find the Bosch relay locally. It can be purchased from Crutchfield (800) 955-3000 (Part No. 120E5000).
If you would like wiring diagrams for your specific application and/or information on custom built switch panels, please supply the following information:
Year, Make and Model, Engine Size, TPI, TBI or Carbureted, Single or Dual Fans, Which products and options (e.g. Option #1a, #2b, etc.) most interested in, your street address, and e-mail them to:
William H. Weissman
tplsz87@cs.com
Stan: i have pm'd the correct PDF file to your inbox and placed here as well, any more problems just let me know. this has worked out form me so much!
http://members.rennlist.com/3liter6/cool8dual.pdf
Option #3a
Option #3b
Option #3c
Summary - Dual Fans
Modes of Operation
Wanna run???
Modes of Operation
Wanna run???
Additional Part
SPDT relay
William H. Weissman
tplsz87@cs.com
#55
Car: 87 GTA
I got the pdf from Willie today. Thanks Willie! I look forward to doing this come warmer weather this year.
#56
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You going to share it?
#57
Car: 87 GTA
I can, but Willie will respond, if you just email him...
tplsz87@***.net
Keep in mind, this one is for a dual fan set up...My 87 GTA 350 TPI. I have zero knowledge of wiring differences between years, or the differences between single and dual fan setups.
tplsz87@***.net
#58
Thanks for sharing that - appreciate it!!!!
#59
Re: Willie's updated Total Fan Control
When reading on thermostats I found some listed the specs as a "static" spec. Simply put, a 180 T stat isnt fully open till 195 degrees(dynamic spec). So a 170 might be around 185 degress at full open. That is whats important, what is full flow at full open.I know this regulates the low end temp as well, but if its not open all the way no easy science can be applied to volume. Just because it starts to open at 180 doesnt mean its "open all the way" .A pot of water and a thermometer on the stovetop will prove this.
I believe that is why the 170 is the correct choice and is best suited for this, and was choosen by the experts. I use it in conjunction with a napa ( Echlin ) fan switch(#FS158)in the head ( dual set up, 92tpi convertible FB, and a 91tpi convertible Z) Fan on at 199, and off at 189 degrees. Rarely goes over 205, and transmissions are not cooked, which is another side effect of high heat, which both run on royal purple (10 per quart atf) my 2 cents
#60
Car: 1989 Pontiac Trans Am
Engine: 350 TPI L98
Axle/Gears: The ones with the teeth.
Stephen, thanks for attaching the dual fan pdf. Did Willie send you schematics to go along with this as well? Seeing a wiring diagram would really help.
#61
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
Does anyone have a picture of the relays for the fan control. I have a wiring diagram from TPLSZ87 but I dont seem to have the wire colors he states my cars has. Are the relays on the firewall drives side and which one is for the fans, I have a 91 Z28 305 TPI auto with air and dual fans. The GM service manual is differant colors than what he states. Dont know if I am just not getting it or what.
John
John
#62
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Yea the pic you took is the fan relay and what should be the fuel relay. Since you colours are different though, unplug one and try to start the car. If it won't start, it will be the fuel pump relay.
You need to stick to what your book tells you especially, if it the actual wires match to the wiring schematic. You'll just need to crossreference your wires to what he says they're supposed to be.
#63
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
I did some searches and found a differant wire diagram and read the instructions again and it final sunk in. The instructions Willie posted are right on (of course) I just am a little slow I guess. Looking forward to cooler water temps when we go cruising. I will post a detailed step by step with pictures when I get done.
Thanks for the feedback I received.
John
John
John
John
Speedgraphic (06-15-2020)
#66
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
On the website !
For dual fans:
https://www.thirdgen.org/electric_co..._spec_mod_dual
For single fan
https://www.thirdgen.org/electric_co...pec_mod_single
Or in this thread...
For dual fans:
For single fan
#67
Is someone having picture of an installation? Where to get the wire threw for switch and or led?
#69
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
WHY is this a sticky if the OP doesn't even host the PDF files anymore. Now I have to go searching again, see this is why TGO is sucking more and more everyday.
I have a guy who needs to learn how to install and control his fan and I was going to refer him to this STICKY but cant because now he has to go back searching for the damn PDF files again ANYWAY.
WTF is the point of having all these stickies if all the files and such are no longer available in the first post they were put in?
TGO better get on the ball and fix all these broken links, no longer updated stickies and pictures that are no longer hosted keeping a lot of people from seeing what they need to see especially in a write up with pictures.
Take care. I see they were posted later in the thread but still, its STICKY not a hey come in here and find the STICKY.
#71
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
There is a slight problem with the single fan tech article. Not all 86 TPI cars have the fan temp sensor in the passenger cylinder head. Mine doesn't and the fan is controlled by the ecm.
Possibly because my car was built late into the 86 model year, I don't know.
Just wanted to add this for those searching for the info so they won't be confused if they don't have the sensor in the passenger head.
#72
FYI also avoid wiring both fans to 1 controller. I had one of the controllers burn out. Better off buying 2 controllers and each fan gets 1 switch.
#73
Car: SOLD!!!!!
wow thats a lot of stuff to do to control fans. all i did was install the flexalite controller that controls both fans. it also has provisions for a/c and turn on and off switches in one unit. it also ramps up to 60% at first and then will go to 100% if needed.
#75
Car: 89 trans am
Engine: 350 tpi
Transmission: 700r4 not for long if i can help it
im wondering if the make a board that can be wired into my fan control where it will give me a digital readout of what % the fan is running at the temp of the motor and allows me to chose at what temp i want the cooling fan to come on at with an override switch. i have been looking for mounts with something like that and can find anything other then comp cooling system stuff and that wont handle 15 amp.
#77
Car: 88 IROC-Z
Engine: 5.7 TPI
#78
Willie is still out there but hasn't been on the boards for quite a while. He's still a moderator on the H/R forum also.
#79
Car: 92 RS
Engine: 305 TBI
Transmission: 700R
Axle/Gears: 273 Pos
I'm sorry I'm kind of new to this posting. Can you tell where I can find Wilie's updated total fan control posting
#80
Car: 88 IROC-Z
Engine: 5.7 TPI
Try sending him an email. tplsz87@***.net Do you have single or dual fans? Here is the dual fan info
Here is a bunch more stuff. The single I believe
#82
Car: 1986 IROC-Z28
Willie said he doesn't support this anymore...he told the mods on here to take his email off but they haven't listened.
I installed the hayden 3647 as the instructions requested...put the probe in boiling water to test and the relay clicks but the fan doesn't work. Any help?
I've been driving the car everyday...the fan works stock before I did this.
#83
I wanted to let anyone know that Derale has modified the 16759 kit now. So if you follow the gmtips.com link on how to wire the system with the GM option etc, it is NO LONGER VALID. The new relay is a GROUND switching circuit, unlike its predecessor. I am going to post a thread to see if we can figure out a new schema.
#85
I did the mod using the new style. 1 Derale fan controller is bad. I had to replace 1 unit of the 2 I purchased already. 1 unit can only handle 1 fan. But even then I had it die about 2 months after purchase. I would avoid derale.
#86
Car: 88 IROC-Z
Engine: 5.7 TPI
Ok thanks castro. I assume it made a big difference when it was actually working?
Anybody else?
Also did anyone come up with a cool way to mount the switches and LEDs without hacking up your car? I'm picky about that.
Anybody else?
#87
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I build electric fan relay harnesses (which meet J1128 specs too, btw) for a variety of applications as well as stock replacement parts for such kits if anybody needs assistance or wants advice on a particular setup, drop me a PM I'd be happy to help you out! Of the many fans I build harnesses for, they include:
Lincoln Mark VIII HO single speed
T-Bird 2-speed
Tuarus 2-speed
LS1 dual fans
LT1 dual fans
RamCharger style dual fans
-and, I have designed my own 2-speed relay kits as well as the only 3-speed fan relay kit on the market! That kit can make any single speed fan behave like a 3-speed fan-this kit will work with standard single speed, dual fans as well. PM me for details if you'd like.
T-Bird 2-speed
Tuarus 2-speed
LS1 dual fans
LT1 dual fans
#88
1 Post
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
The links on post one aren't working for me. I have no idea why. Please help. I'd like to see the single fan link.
#89
Car: 88 IROC-Z
Engine: 5.7 TPI
#91
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Google search on "mini rocker switch LED" result in:
parts-express $3.15 in green and red
ebay $10 - blue or green
#92
Car: 88 IROC-Z
Engine: 5.7 TPI
The second link in post #80 includes the following picture. I think that is one of the best examples of what you are looking for.
Amazon $6 green
Amazon $6 green
Anyone know how you get fans, auto 1, auto 2 etc printed on these switches? That is sweet looking.
#93
Has anyone done the Hayden 3647 mod? Looking to do this and needed the installation instructions for our cars I have a 87 350 tpi no a/c I know this is an old thread any help would be great
#95
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Did you read through the thread or only check the first post?
Here are a few that I noticed:
https://www.thirdgen.org/electric_co...ec_mod_single/
https://www.thirdgen.org/electric_co...spec_mod_dual/
https://www.thirdgen.org/forums/atta...amaro_wire.jpg
https://www.thirdgen.org/forums/atta...maro_wire1.jpg
https://www.thirdgen.org/forums/atta...amro_relay.jpg
#98
Car: 1992 camaro z28 5.0
Transmission: auto
Hello,
I'm new to the group. I have been searching and cant find any updated part numbers for the "Fan cooling switch" mine is under the throttle body and is a 2 terminal type. i have a dual fan setup from factory. I need to know what the part numbers are for the colder switches, on/off temps. Any help will be appreciated.
thanks again,
thanks again,
Hotrodboba400
12-10-2019 07:07 PM
