Overheating Leaking Coolant HELP!!
Old 12-06-2004, 10:14 PM
JMONEYTREE's Avatar
Car: 91 Camaro
Just wanted everyones opinion. Its a 1.6L Chevrolet Nova Toyota Motor....Its overheating and coolant is leaking from the overflow tank. We just had the headgasket done along with machining the head and a new thermostat. But the gauge says its close to overheating. Any Idea's????Please Help!!!
Old 12-07-2004, 04:44 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
This is going to get closed...
The sender maybe?
Old 12-24-2004, 07:02 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Get a proper engine in there and it should work. hehe
Join the club, I have the same problem, but with factory L98 TPI and auto trans. Check all your cooling lines and accessories, you have to troubleshoot by way of elimination, so if somethings working, you can rule it out basically
I had trans cooling lines in addition to the hoses and electric fans to consider. Still not sure if the fans are coming on correctly, for instance
Bill
sheachopper
07-31-2019 11:27 AM
RS Reaper
10-17-2018 07:52 PM
Reid Fleming
10-10-2015 09:56 PM
ULTM8Z
10-02-2015 01:25 PM
aaron7
09-30-2015 09:15 AM
Quick Reply: Overheating Leaking Coolant HELP!!
