WHERE O WHERE IS THAT TEMP SENSOR?
Car: 1982 Pontiac Trans Am (Recaro)
Engine: 5.0 v8 (305 TBI)
as in the title am havin a tw@tin time tryin to find the temp sensor i have a ruff idea thats its on the drivers side but where on the engine is it? the only thing i can see is the exhaust manifold from the top and wires to the spark plugs from the bottom.
if anyone got any pics it would be great or should i get some specs lol how can it be this hard?
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
CTS - Thermostat housing (For ECU)
Gauge Temp - Drivers side, between 1,3 sparkplugs. under manifold in head
Fan Switch - Passenger side, between 6,8 sparkplugs, under manifold and head
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Forshock has you looking in the right spots.Except if your motor is an LU5 305(CFI) the CTS will be on the passeger side front of the intake(partially hidden by the alternator).
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I am not sure on the carbed engines, but on my TBI there are two temp gauges. CTS located infront of the intake, and the sender for the gauge between 1-3 sparkpluggs. I think you are looking for the CTS which should be close to the waterneck on the intake.
Good luck.
Good luck.
