heating problem 1992 camaro with 350 vortec
Old 07-22-2006, 07:33 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I have a 1992 camaro with a 96 vortec 350 that has a heating problems. any ideas of what the problem is?
Old 07-22-2006, 07:35 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
You mean it's overheating? If so, it could be a lot of things. Give us some more details on the engine and the symptoms...
Old 07-22-2006, 07:39 PM
Axle/Gears: G92
it only heats up when sitting for a long time in traffic or sitting....besides that if its moving its not really hot at all.
Old 07-22-2006, 07:49 PM
Axle/Gears: G92
so does anybody have any ideas of why this is happening?
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
What does the temperature rise to?
Have you put in new coolant and flushed the radiator lately? Are the fans working? If all that is working fine, then you may have to look into a new radiator to cool that 350. But try the basics first.
Old 07-22-2006, 07:53 PM
Axle/Gears: G92
the coolant is fairly new but i havent flushed the radiator lately and everything is working fine...its not heating up to bad but just enough to worry me lol.
Old 07-22-2006, 07:54 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Is it getting to around the middle of the thermostat? That's what it usually gets to before the fans kick on. A new thermostat (maybe 180*) and/or a fan switch can fix that.
Old 07-22-2006, 07:56 PM
Axle/Gears: G92
the coolant is fairly new but i havent flushed the radiator and the fans work fine. its not getting really hot but just hot enough
Old 07-22-2006, 08:00 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
And as long as it isn't getting in the red, don't lose any sleep over it.
Welcome to TGO by the way.
Old 07-22-2006, 08:03 PM
Axle/Gears: G92
thanks but it is just barely in the red not to bad but alittle in the red.
Old 07-22-2006, 08:09 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Oh, well then you should worry. The engine shouldn't be anywhere near that. Double check your fans. Flush out the radiator and block, put in new fluid (add some Royal Purple "Purple Ice" to help keep it a bit cooler while you're at it). Invest in a new thermostat (they're like $10) and if none of that works, look into an aftermarket aluminum radiator or fan set up.
Good luck. And hopefully someone else can chime in with some more helpful advice.
*Edit* Also, if the engine is that hot for too long, it can really mess up the engine oil. Check that before you drive the car again.
Old 07-22-2006, 08:12 PM
Axle/Gears: G92
ok thanks for the help! how do you post pics of your car on here?
Old 07-22-2006, 08:17 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
When you're writing an entry just look up at the toolbar of the text box and under the "undo" button is an icon of a picture with mountains in it. Just click that and copy the web address of the picture into that box.
And if you want a custom signature like I do (under all my entries) then go over to the photoshop request board https://www.thirdgen.org/forums/sign...shop-requests/ and post some pictures of your car. Then in a few days a sig with your car in it will magically appear. They can also put new wheels and colors on your car.
Old 07-22-2006, 08:30 PM
Axle/Gears: G92
ok thanks
Old 07-23-2006, 12:32 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
might want to check and see if you still have the factory plastic duckting that direct air to the radiator. most people remove it because it scrapes on the ground. If it hits 220 no big deal. most switches dont come on before that regardless of what thermostat you have.. if it hits the red and then drops again into the median range then you could step down to a lower range switch.. i'm not sure which one but there was a thread her from a few years ago that had the specific part number. If it doesnt drop then your fans arent coming on.
Old 07-23-2006, 10:36 AM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
He says it only heats up when it's sitting in traffic though. So I'm guessing that the air dam is still there. And the fan switch is another good idea.
Old 07-23-2006, 08:56 PM
Axle/Gears: G92
92camaroJoe
07-29-2023 07:57 PM
Vintageracer
01-10-2020 05:33 PM
84z96L31vortec
08-20-2017 12:16 AM
Quick Reply: heating problem 1992 camaro with 350 vortec
