Heat only from Defrost
Old 02-18-2009, 03:06 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The heat in my car is only coming from the defrost vents. I know that the main cause of this is because of a broken vacuum line somewhere. So I put a vacuum gauge on the hard vacuum line that comes through the firewall and applied vacuum to it while holding my finger over the vacuum connector that goes to the heater controls. If there is no vacuum leak at this vacuum line then where would it be?
Old 02-18-2009, 06:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Heat only from Defrost
The switch itself is often the culprit. Stick you ear to the HVAC and listen. Should you hear the tell-tale hiss, I "believe" this is what you'll need: Valve Vac Sel GM part # 16032395.
JamesC
Old 02-19-2009, 02:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well I changed out my heater controls with another one that i had and it is still doing the same thing. Any other ideas?
Old 02-21-2009, 07:18 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
The heater controls you put in may be bad too.
Old 02-22-2009, 11:07 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Does the hard vacuum line from the a/c harness have to go to a check valve or can it be hooked right up to a direct vacuum source?
Old 02-24-2009, 06:33 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
It ended up being the part that James mentioned. Thanks for the help.
sheachopper
07-31-2019 11:27 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
whibbs
Exterior Parts for Sale
09-28-2015 07:53 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: Heat only from Defrost
