Does anyone have a correct cooling fan wiring diagram?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Does anyone have a correct cooling fan wiring diagram?
Next page of this forum -
https://www.thirdgen.org/forums/cool...-diagrams.html
Tech articles, from the main page of this site -
https://www.thirdgen.org/technical-articles -->> http://92b4crs.tripod.com/86wiring/86wiringindex.html -->> http://92b4crs.tripod.com/86wiring/dia-pics/31-1.jpg
Google -
http://www.austinthirdgen.org/index.php?pid=19 -->> http://www.austinthirdgen.org/mkport...ine_wiring.gif
HTH
Google -
HTH
1 Post
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
I have the factory manual for for a 90 firebird that includes single and dual fan setups, as well as that garbage Haynes manual. If you still need them, I can scan in a copy when I get home tomorrow.
However, I would reccomend using an aftermarket controller, they are more reliable and eliminate the factory system completely.
Google -
HTH
Google -
HTH
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I use a Flex-a-Lite fan controller - much better and more reliable than the stock setup. I always had problems with the fan switches not working - I tried GM, cheap autozone, even expensive Hypertech - all went out in under 2 months. I got fed up and got this Flex-a-Lite controller and it's never failed me 3 years now. It's fully adjustable, has provisions for single or dual fans, works with A/C, has options for manual on and manual off switches in the cabin.
So it doesnt have a temp thing that goes into the block right? You just insert the probe in between the radiator fins. Sounds a bit dangerous. What if the thermostat sticks and your cylinder heads crack? Will the Flex a lite still pick up the rise in temp?
1 Post
Car: 90 Trans Am
Have a great year!!
1 Post
Car: 90 Trans Am
Have a blessed new year all!!!
Engine: TPI 305/ v6
I'm not basing my opinion of stand alone controllers on that though.
1 Post
Car: 90 Trans Am
I understand that. I used a hayden first- it didn't even last 2 weeks.
1989formula5.7l
08-17-2015 02:56 PM
eightsixseven
08-14-2015 03:09 PM
