Blower motor where is it?
Old 02-17-2010, 04:02 PM
augie1209's Avatar
Anyone got a pik of where the blower motor is for the a/c and heat? I'm pretty sure the problem is the motor... Any1 got trial and error suggestions for trying to figure out if it is the blower motor? It has come on before and i can feel the cold and hot air come out.. .its just when its on high it doesn't blow i can just feel the diff in temperatures... let me know and that pik would be great thanks
Old 02-17-2010, 04:16 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Re: Blower motor where is it?
It's under the hood on the passsengers side of the firewall. But if it runs in every speed except high, it's probably a bad high speed relay, which is right next to the motor.
Old 02-17-2010, 09:24 PM
augie1209's Avatar
It doesn't run in every speed at all... i got it last august and one day it decided to turn on but only once.. i can feel air coming from it hot or cold but no power to it at all other than that one time.. not even sure if hot and cold was from engine bay either and is it in interioir or exterior
Old 02-17-2010, 09:29 PM
Drew's Avatar
It could be the switch, wiring, relays, resistor pack, or the motor. Look around a bit on the electronics board, and this board, it's been discussed a few times at least. It might also be helpful to know exactly what year, make, model, etc car you're working with.
Old 02-17-2010, 09:33 PM
augie1209's Avatar
Car is 92 z28 5.7 350... A new engine was put in before i got it and that owner said it did'nt work... but didn't stop me from buyin it ... anyways yea it has a little hissing sound when i turn the switch thats about all i have observed
Old 02-17-2010, 09:43 PM
Drew's Avatar
Try setting the slider to vent, and the fan to one of the medium settings. Then go under the hood and tap on the blower motor case. If you need to know what it looks like, just go to any auto parts website and look up a replacement vent fan motor. You could also set the fan speed to high and disconnect the plug to the motor, you should have battery voltage on one wire and ground on the other. If there's voltage and the fan doesn't run it's time for a new fan motor.
Old 02-17-2010, 09:46 PM
Drew's Avatar
Check out this thread... https://www.thirdgen.org/forums/elec...ater-woes.html
I posted all the diagrams and the troubleshooting steps from the GM service manual for a 91 Camaro, 92 is the same.
Old 02-17-2010, 10:56 PM
augie1209's Avatar
Thanks alot guys btw thr are quite a few wires not hooked up in engine bay hopefully its not what i need but heres a pik let me know if you guys see anything
Attached Thumbnails Blower motor where is it?-l_7f767b209dea4b6f9f86b98f145b8356.jpg
Old 02-17-2010, 11:37 PM
Drew's Avatar
The fan motor would be just out of frame at the top left. The two plugs chillin out on the passengers side valve cover are from the AIR system which someone has deleted. The breather on the passengers valve cover would normally be connected to the capped port on the throttle body. The valve covers are aftermarket, and the original engine for the car should have had centerbolt heads, so unless there are adapters I'd guess at least the heads have been changed. I'm not sure what's up with the blue wire loom cutting across the engine compartment. Just from the pic I can't see anything that would cause the fan not to work, but who knows what's hiding.
Old 02-18-2010, 12:01 AM
augie1209's Avatar
The blue loom is just some custom electricals i put in... so i should look at top left where the fan should be? Is it on top or under the car? Thanks for the help again... not much of a mechanic just like the electronics and some body work
Old 02-18-2010, 11:12 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
If it is the blower motor I've got a used one boxed up ready to go. $30 shipped. I bought it off of eBay awhile ago but I ended up just having a hose disconnected. Now it's
just sitten in my room. Pm me if ur interested, just tryin to break even.
Old 02-18-2010, 01:37 PM
Axle/Gears: stock
Old 01-16-2017, 04:23 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Here is the blower
Old 01-16-2017, 04:24 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
and here is the climate control diagnosis I did
Frozer!!!
01-19-2024 04:55 PM
Bubbajones_ya
08-31-2015 12:02 PM
zayne0
08-24-2015 07:22 PM
mhatfield 14
08-15-2015 10:47 AM
Street Lethal
08-13-2015 08:28 PM
Quick Reply: Blower motor where is it?
