What controls the fan?
Old 11-28-2010, 11:16 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
What is the sensor or switch that controls the fan? My car keeps overheating when it runs for more than maybe 20 minutes. The temp gauge hits the red.
I've been told by my uncle that it is the coolant temp sensor that turns the fan on and off. I search that on autozone, and also found a fan switch. What exactly do I need to make the fan turn on, and where is it located on the car?
As of now, the only way to turn the fan on is to turn the AC on.
Thanks!
Old 11-28-2010, 11:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What controls the fan?
The primary fan is controlled by the ECM, the secondary by the fan switch.
Old 11-28-2010, 11:40 PM
chevydrvr's Avatar
But I only have one fan?
Old 11-28-2010, 11:49 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If you have TBI, there is only 1 fan. It is controlled by the fan switch only, not the computer.
Old 11-29-2010, 04:51 AM
chevydrvr's Avatar
Okay, What is the switch called? I think I need a new one?
Old 11-29-2010, 12:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
http://www.autozone.com/autozone/par.../N-iteceZ9pd8z
If that works. It's called a fan switch (AZ calls it a Radiator Fan Switch), it's located pass side head between #6 and #8 spark plug. In the head, NOT the block (there is also a very very similar looking sensor in the block same side, it's the knock sensor).
Old 11-29-2010, 01:04 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, if the fan works when you turn on the AC that means your fan and relay are good and you just need to replace or properly connect the fan switch described by Newbie above. You may want to chjeck your wiring first. Grounding the wire to the switch with the key on should turn on the fan. There are alternatives to the stock temp switch, some of these are discussed in this thread
https://www.thirdgen.org/forums/cool...ernatives.html
Old 11-29-2010, 02:13 PM
chevydrvr's Avatar
When I get the chance, I'll check the wiring, but how do I check it with ground like you said?
Old 11-29-2010, 02:41 PM
Car: 1992 RS
Engine: Carbed 350
Just touch the wire that goes to the fan switch to any bare metal on the car - with key on the fan should run - that lets you know the wiring is good, and probably just the switch is bad.
Old 11-29-2010, 02:46 PM
chevydrvr's Avatar
Okay, thanks! Ill try that. If the wiring is good, then I just need what he linked to above?
Old 12-01-2010, 07:51 PM
chevydrvr's Avatar
Will the fan switch from autozone (part number sw500) work on my 92 rs 305?
http://www.autozone.com/autozone/par...artNumber=true
And I know this is off topic, but will this idler arm work too?
They both say they fit my car, but I don't really like to trust that. Thanks!
Old 12-04-2010, 01:05 PM
chevydrvr's Avatar
I knew that part, but I just wanted to know what specifically tells the ECM to turn the fan on. I've now learned that the fan is controlled by a relay which is either controlled by the AC or the ECM. I also learned that either the switch is bad or the relay. The relay is good because the fan comes on when I turn on the ac.
I ordered the switch from autozone above. Please let me know if it'll work. And, just on a side note (so I don't have to start a complete new thread for one quick answer) will the idler arm work?
Thanks!
Old 12-04-2010, 02:20 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The ECM has nothing whatsoever to do with the fan. Either the fan switch or the AC on switch grounds the relay which sends power to the fan. Period
Old 12-04-2010, 02:25 PM
chevydrvr's Avatar
Alright. I got it. Now will that switch I ordered work? That's all I'm asking for!
Old 12-04-2010, 03:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Should be just fine. Make sure the wiring to it is kept away from the exhaust manifold so it stays intact and melt free
Old 12-04-2010, 03:23 PM
chevydrvr's Avatar
Thanks!
Old 12-05-2010, 11:15 AM
chevydrvr's Avatar
One more question... Will I have to drain any fluid before removing and replacing the fan switch?
Old 12-05-2010, 02:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Coolant will come out. You can drain the whole engine and later refill or just try and do it quickly to minimize the loss. Depends on whether some spillage will bother you or not
Old 12-05-2010, 06:24 PM
chevydrvr's Avatar
Can I possibly hurt anything if a little spills out? I plan on using a rag to quickly block it and then put the new switch in.
Old 12-06-2010, 12:24 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Don't drink it and you'll be fine
Old 12-06-2010, 02:13 PM
chevydrvr's Avatar
Thanks so much for the help!
gta892000
08-11-2019 11:16 AM
Bubbajones_ya
09-14-2015 08:38 PM
formula1LE
09-12-2015 08:31 PM
scottmoyer
09-07-2015 07:06 PM
85Special
09-03-2015 04:21 PM
Quick Reply: What controls the fan?
