Missing Relay Plug
Old 03-28-2012, 04:19 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Missing Relay Plug
So the PO of this car sold me it with nothing connected.. in the love i fell for the beauty for the car i bought it and have been putting it back together since last year. Now the engine runs and i just need to finish a few things here and there, but when looking at alldata and these forums i had an issue when i tried to find a mising cable....
Well this cable conectes to a relay next to the fuel pump relay.. i know its not the fuel pump because it has 5 wires.... so it must be A/C or Fan... now the relay is there. but i cant seem to find the plug that connects to the relay!
ill post some pics in the morning
Also how do i test and see if my Fan is working?
Old 03-28-2012, 10:46 AM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: Missing Relay Plug
That is your fan relay. To test the fan just run a jumper wire from the battery+ to the orange(?) wire on the connector to the fan itself and ground the black wire. The fan should spin.
Old 03-28-2012, 02:10 PM
pvr007's Avatar
Engine: 305 TBI
The fan is conected by pig tail
Old 03-28-2012, 02:41 PM
pvr007's Avatar
Engine: 305 TBI
The pi tail only has 2 cables... Black with red stripe and black... I see another connection there but i cant find a cable for it... Also i bought this fan from someone here that told me it would fit.. And it did.. I mean its like 4 inches a little bigger but it matches.. I think
Old 03-28-2012, 04:38 PM
91 1LE's Avatar
Car: '91 1LE
Ground the black and hook the black/red wire to battery +. This will tell you if the fan works. You can use the stock relay to power the fan if you can find the connector or you can buy/make a new harness and relay. Either way isn't difficult.
Old 03-28-2012, 06:39 PM
pvr007's Avatar
Engine: 305 TBI
I disconected it and now it works... Weird...
Glowsock
01-09-2017 04:06 PM
Bryan F
08-27-2015 07:28 AM
Bert87
08-23-2015 03:50 PM
Bryan F
08-18-2015 02:28 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Missing Relay Plug
