DUEL FAN TO LARGE SINGLE FAN?
1 Post
Car: 1987 IROC Z
Engine: L31 VORTEC
Hello to all,im running factory duel fans on my 87 roc and been having alittle trouble with them.im wanting to pull the duel fans and replace with a large single fan,has anyone ever done this and any suggestions on what fan i should use or the size.thanks
Engine: 4++,350 & 305 CIs
Re: DUEL FAN TO LARGE SINGLE FAN?
I would fix your factory setup.
Whats wrong with it?
Car: 1990 Camaro RS
Engine: L05 TBI
I agree with TTOP350. I just had to replace my single fan with a dual because the single wasn't pulling its weight. Probably save you some cooling issues if you stick with the dual.
1 Post
Car: 1987 IROC Z
Engine: L31 VORTEC
Well one of the fans makes noise when its running.the other thing is they or hooked to a toggle switch,which i hate.i bought an adjustable thermostat from summit to run the fans to bypass stupid switch but it will not work,it worked for about a week then quit sent it back got another one and it did the same thing,i think one of the fans is grounding out or somthing wich is causing the thermostat relay not to work.basically i think if i get a single fan my thermostat would work properly and fix my problem?!!
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have a 92 Z vert and I did away with my dual fans and went with a 3500CFM single 16 fan (puller) and I also installed a 14 pusher installed onto the a/c condenser. I have a trans cooler as well on the lower passenger side of the condenser and I have a 5.5 inch fan installed on it. I have relays for each of them and switches for all of them inside the ashtray lid. I have a be cool radiator and a special made lower air dam that is larger and made of aluminum. It drags a little on some places where the front gets low but its all about air flow. The taurus fan is supposed to be greatest thing since sliced bread but I haven't found one yet. I take these fans and put a bead of gasket maker around them and attatch them right against the radiator. One of the flaws of our two fan system is that air leaks from around the fan blades themselves without a shroud. They are not as effecient as the ones with a built in shroud like the all the new cars have.
The adj switch may not work with both fans unless your using the relay ground side to control them.
If its hooked to the positive side of relays you may burn that one switch up.
2 fans need 2 of everything, ideally.
Also if your trying to run it cooler, you need a Tstat, correct fan switch in the pass head and the temp in the chip program lowered.
grab a factory service manual or factory wiring diagram and fix it properly. It will work.
1 Post
Car: 1987 IROC Z
Engine: L31 VORTEC
TTOP 350 you da man,thanks..no running hot issues just trying to fix it correctly.
1 Post
Car: 1987 IROC Z
Engine: L31 VORTEC
hey ttop,one more question.after doing alittle searching i found a fan wiring diagram.the diagram shows how to wire one fan thow do i need 2 relays for 2 fans?im stoping by local advanced to day to get fan switch that screws into head and run wire to relay.
Car: 1986/90 camaro
Engine: 350 tpi
Axle/Gears: 3.73 gears. POSI
i pulled my car out of storage today and driving home and it starts smoking. i pop the hood and smokes coming out of the radiator fan motor. and fans locked up. i turn car off and fan is locked up. im thinking this needs a new motor thats it right?
