Car running hot
Car: '88 IROC-Z
Engine: 305 TBI
Car running hot
My '88 IROC 305 TBI is running hot. Drove it the other day had significant power loss. Fan is working wondering if it wasn't thermostat. Temp gauge wasn't climbing to normal temp. Have aftermarket temp control probe that sticks into rad fins. Help please.
Re: Car running hot
What does the temp gauge say the temperature is? Get an IR temp gun and check the temperatures at the water neck and radiator cap.
is it getting hot in traffic or on the highway?
is the air dam in good shape?
225* is when the factory fans turn on so that is "normal".
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Car running hot
when was the last time the thermostat was changed?
when was the last time water pump was replaced?
winter time i use 195*
summer time i use 160* (i use the ac alot when going to phoenix Az )
have you inspected the oil for a milky looking water color? (oil in water/antifreeze)
to rule out head gasket issue?
Car: '88 IROC-Z
Engine: 305 TBI
Re: Car running hot
Temp gauge was only reading like 150 maybe running down the highway. Put new sensor on it last year so shouldn't be that. Air dam?
Car: '88 IROC-Z
Engine: 305 TBI
Re: Car running hot
Well I tried thermostat but broke one of the bolts so have to get it out first. Water pump quite a while. Haven't checked oil yet. That's 2 different thermostats you mean?
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Car running hot
you broke the thermostat housing bolt? (2 bolts that hold down the housing)
1 is a temp sensor that tells you the temp on your gauges
1 is a thermostat that installs on your intake manifold from upper rad hose to intake
you would know if the water pump is bad pretty quick it be leaking either from pin hole or other places around it.
thermostat housing
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Car running hot
the air damn is what keeps our cars cool when we are driving, air hits the dam which brings up air to the rad
Car: '88 IROC-Z
Engine: 305 TBI
Re: Car running hot
Water pump doesn't appear to be leaking that I noticed. Haven't lost any coolant.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Car running hot
ouchie!! i so would have cryed n yelled an said some choice words loudly.lol
if u can get the other bolt off easy u should be able to remove that bolt thats broken..doesnt take much force to remove or install the bolts. go part store n get a replacement or junk yard typical bolt from chevy engine v8. grab a few from few diff engine just to be safe..
thermostats get stuck open or stuck shut which causes over heating issues
fan coming on ?
fan coming on ?
Car: '88 IROC-Z
Engine: 305 TBI
Re: Car running hot
Yes bigtime. Ya steel bolt and aluminum head though. Bad combination. I have new bolts to replace just have to get broken one out.
Fan is coming on yes
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Car running hot
yea check your oil for possible coolant mix
and change thermostat
you can check the stat by heating up a bowl of water an drop the stat in the water to see if shes opening or not..not accurate by any means but does help to see if its working. there cheap personally id just replace it.
so recap
check oil
change stat.
then let her run n watch temps
without ac on you shouldnt even hit 220 (depending how your area is) or stop at 220.
i have a 160* stat in my car, temps in my area are 90*F++ i dont even hit 220 unless my AC is on..
Re: Car running hot
Hmm, I've always heard it creates a low pressure point just right after the dam, thereby pulling hot air out from the radiator and down underneath. Definately a unique critical piece for proper 3rd gen cooling.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Car running hot
if you think about it, when your driving air is being cycled through the engine bay from underneath the car pushing air in n out, only thing sucks is hot weather, 115* weather in Tempe az highways lol
theshackle
03-05-2017 06:37 PM
db057
08-11-2015 10:11 PM
