Car smells of antifreeze but is not overheating
Car: 89 GTA
Engine: 5.7 TPI
So I come into work today and after getting out I go and put my t-tops back on and as I come to the passenger side I smell antifreeze. Car isn't overheating and there is nothing on the ground. Also no smoke while running I only smelled it after the car was off and I was on the passenger side. Any ideas what I am looking at? Maybe the heater core has a leak in it? I will check that tomorrow. But any other suggestions would be nice too.
1 Post
Car: 1986 Camaro I-ROC
Engine: 305 LG4
Re: Car smells of antifreeze but is not overheating
sounds to me like its the heating core. See if you can feel any coolant in the passenger side carpet. Are your windows fogging up?
Car: 89 GTA
Engine: 5.7 TPI
Summer time I have the tops off and windows down, and no the carpet isn't damp. I haven't took off the passenger side panel. I'll do that in the morning when I get off work
Car: 89 GTA
Engine: 5.7 TPI
Drove the car home yesterday and after getting home I didn't spot any issues. No leaks coming from the engine. No antifreeze on the ground or splashed around anywhere. Car doesn't overheat. I did hear a bubbling sound coming from the overflow bottle. But that was after the car was off. Perhaps the smell was just that coming out of the bottle as it was filling up? I checked the radiator (which is brandnew btw) and the car was circulating antifreeze fine. Also when the car was off the antifreeze came up to the hot line when it was hot. I too am baffled about this as well.
Car: 89 GTA
Engine: 5.7 TPI
Okay I'll do that. Thanks for the heads up! I did also have the coolant system drained and flushed when I had the new radiator installed. Where can I find a new coolant overflow bottle at?
Best/fastest way to diagnose these issues is to pressure test.
You can rent a tool, or use an air compressor, simply fill the radiator with air pressure using the overflow tube usually works fine. It will swell up to it's cap max, around 12-15psi, and then you will be able to find all leaks as it bleeds down and sprays coolant out.
