Heater core leaking
Car: 1985 trans am
Heater core leaking
So my heater core crapped out. Coolant all over the carpet. If I don't use the fan will it still leak? Its an 85 trans am. Want to just store it once returned from paint shop
1 Post
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: Heater core leaking
As TylerSteez mentioned, your core must be replaced or repaired. The original was made of brass. The replacements are made of aluminum. The hoses come from the water pump(supply) and the intake manifold(return). If you have the factory hoses, it can be a little difficult to put a coupler in where the two hoses enter the firewall. This is because there is a kink or jog in the one hose. Better to just remove them both and install a short length of heater hose between the two nipples (water pump and intake manifold). This way you can still drive the car.
