Electric fans, are they worth it?
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
So I have been kicking around the idea of running electric fans on my 84 Z28 LG4 and was wondering if its worth it? I know it will free up some HP and get you some MPG on the highway. Just wondering what kits people use and how easy it is to install an aftermarket kit and if I should go with a larger amp alternator. Any input will be appreciated!
Received 1,670 Likes
Re: Electric fans, are they worth it?
Hard to say about "worth it". The usual standard is, if it costs less than $10/HP.
"They" say a clutch fan consumes as much as 12 - 15 HP at high RPM. So by the above standard if you could do it for less than $150 or so, it's good. But there's other considerations besides just HP, like gas mileage.
Personally I'd do it. You could just get the stuff off of a L69 car.
Car: 1984 Z28
I was looking at the factory L69 set up but they are getting harder to find, and was more leaning to an aftermarket set up with a matching wiring harness and sensor to kick on and off. and also should I go with a larger alternator because I know electric fans can take quite a few amps to run.
Car: 1991 CAMARO Z28 VERT
Engine: LS2
Transmission: MAGNUM T56
Axle/Gears: STOCK 7.5/3.73
AS FOR THE RELAY I WOULD GO TO YOUR LOCAL PARTS STORE OR ORDER YOU ONE ONLINE,ALOT OF THEM ARE ADJUSTABLE SO YOU CAN MANAGE THE, OR YOU CAN JUST BUY ONE THAT WILL TURN ON AT A CERTIAN TEMP.
GOOD LUCK
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
factory style set up with relay and temp switch is an economical option. you can gank a fan relay off pretty much any later model car at the yards (the LG4/L69 relay's connector doesn't hold up well but a later one is good). a new motor along with a factory single fan set up is near perfect.
