Coolant around thermostat housing
Old 01-12-2017, 08:06 AM
Kdog901's Avatar
Hello everyone I'm Kenneth and I got a 76 K5 with a 87 l98 out of a Camaro 350 and I'm getting coolant around the thermostat housing just replace the housing and this is the second gasket I've had in within 2 months it's still leaking I'm wondering if it's coolant passages are the bolts that go into the intake intake gasket need help
Old 01-12-2017, 08:59 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Coolant around thermostat housing
The intake gasket can blow through. The bolts do not extend into coolant passages. No need to make two threads on the same issue.
Old 01-13-2017, 12:28 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You can set the new housing on a flat surface and shine a light at the base on the far side preferably in the dark. If you can see light shining under it than either get a different one or file it flat.
Use a very fine sand paper on both the manifold and the base of the housing and clean it off really well.
Thread the bolts into the manifold without the housing to see if they are going in far enough to pull it down nice and tight.
Use a paper "Fel-Pro" gasket and if you want a "small" dab of high temp "RTV" black gasket maker on the bolt threads.
Last resort would be to double the gasket.
The holes that the bolts go into can strip easily.
I have had to use "hela-coil" on more than one so be careful.
Old 01-13-2017, 11:36 AM
Kdog901's Avatar
Already has a heli coil in one
Old 01-13-2017, 08:01 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
The thermostat housing isn't chrome, is it? I've seen a LOT of these leak. You can try flattening the bottom (gasket surface) yourself, or have a machine shop touch it up.
Old 01-16-2017, 11:25 AM
Kdog901's Avatar
So no one thinks it's a loose bolt or an intake gasket or water pump gasket or throttle body hose everybody thinks that's my new thermostat housing with the second gasket already
Old 01-16-2017, 02:58 PM
Kdog901's Avatar
Found the problem it was a intake gasket right above the coolant Passage can see a crack in it coolant flowing right out I knew it wasn't the thermostat LOL
Old 01-16-2017, 03:25 PM
Engine: Lb9
Transmission: M20
Tpi intakes pit around the coolant ports. You might want to put a thin film of liquid teflon or rtv around both sides of the intake gasket.
