how to install toggle switch for fan
Old 02-18-2017, 09:09 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
how do i install a toggle switch for my dual fans to work . pics diagram would be great . just need help
Old 02-18-2017, 10:15 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: how to install toggle switch for fan
Why? Does one work and one not, or do both not function at all or not like they should?
Old 02-19-2017, 03:53 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
if i can't get the fans to work right i just need a back up plan
Old 02-19-2017, 04:13 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Why don't you reread your fan post all the information for you to fix the issue is there .
https://www.thirdgen.org/forums/dfi-...r-ecm-bad.html
Old 02-19-2017, 04:26 PM
Engine: Lb9
Transmission: M20
You can wire it like this with a spdt relay. The thermo switch can be a backup.
Here is some info on lower temp switches for the fan:
This fan switch turns ON @ 212 degrees & OFF @ 204 degrees:
Four Seasons 35946 (this is the GN sensor, GM OE # = 3053190)
(STANDARD MOTOR PRODUCTS Part # TS136 )
TS136 - closes 204 degrees
TS85 - closes at 211 degrees
TS147 - closes at 222 degrees
