Datalogging 16196396 ECM
Car: 1994 Chev K2500
Engine: Chev 350
Has anyone succesfully been able to do datalogging with this ecm(16196396)? This is what I have in my 1994 Chev k2500. I recently did an engine swap and had a custom chip burned. I would like to do some datalogging to see if the chip could be tuned better. This seems to be an odd ecm so I havn't found much support for it. I have built my own cable for 160 baud/pin E and have also purchased a prebuilt cable that is supposed to work at 8192 or 160 baud. It has two different wires for the different speeds. I have tried both cables with TTS Datamaster, winaldl, Tunerpro, carbytes, with no luck. The closest I have come was some raw data being displayed with winaldl using 160 buad. I'm not sure if this ecm is 8192 or 160 baud. When I have tried at 8192 baud I use pin M on the aldl. Any suggestions?
1 Post
Car: An Ol Buick
Engine: Vsick
Re: Datalogging 16196396 ECM
He might have used a different code then was original. Try to link with it using the stock chip.
Engine: Chev 350
Thanks for the info Grumpy. Now I know at least what baud rate to use. Any recomendations on software to use? Is there some software that would give me just the datastream so I could at least make sure there is communication going on? Or maybe some other test to make sure my cable is working? You mention that my custom chip could have a different code from the stock. Do you mean the broadcast code? I though the ecm model was the only thing that determined the format of the data stream. Sorry for all the questions I'm just still trying to learn.
1 Post
Car: An Ol Buick
Engine: Vsick
I'd imagine Diacom would read it.
If you can read the .bin and email it to me, I might be able to figure out what mask your dealing with.
efiguy
09-27-2015 01:30 PM
