yet another calmap question
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
my question is about the ignition menu in calmap v6.32.i had someone progam my base calibraions for me and in the ignition map fuction where it says "ignition angle(deg btdc)" the person has put in 25deg.am i supposed to cooridate my dampner and timing tab at 25 degres?that sounds awfully advanced to me.basically what should i set my dampner at?i am using a late model distributor with a remote coil and the dfi box is controlling timing.so basically when i unplug the est connector and check timing with a light what should i set it at?that 25 degrees is total timing correct?if its total it doesn't seem like much.any help would be appreciated....
mike
mike
Car: check
Engine: check
Transmission: check
I am not that familar with the Accel systems, however, I checked the CALMAP instructions and they say to set the initial at 6 deg BTDC with bypass open.
http://mrgasket.com/pdf/ProRamSmall.pdf
http://mrgasket.com/pdf/ChevyLT1.pdf
The second link covers both SBC & LT1.
Here is a blurb:
"In order to set the initial timing, the ignition bypass
connectors (white-one pin connector), incorporated into the
HEI leg of the main wiring harness, must be disconnected.
With the engine running hot at 800 RPM, manually adjust the
distributor to 6 degrees BTDC. Once adjusted, reconnect the
ignition bypass line. As soon as you connect the bypass line
the timing will then be controlled by the ECM. The spark
curve is preprogrammed into the ECM from ACCEL/DFI. It
has as initial timing of 20 degrees BTDC and a total timing of
34 degrees BTDC in by 3000 RPM. The timing curves, as well
as all other tables in the ECM, can be adjusted to better suit
your engines requirements using ACCEL/DFI’s calibration
software CALMAP."
HTHs,
RBob.
Here is a blurb:
software CALMAP."
HTHs,
RBob.
