Where are you mounting your stand alone ECM?
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a Holley Commander 950 Pro with Injector convertor box and I am wondering where people are mounting their stand alone systems? If you are mounting under the passenger side dash, what are you using to mount the controllers? Any pictures would help to me give me ideas.
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Re: Where are you mounting your stand alone ECM?
I have a FAST XFI, and since it has a pretty red anodized aluminum housing, plus LEDs that blink whenever an injector fires, I mounted it on the right-hand kick panel in the passenger footbox. It's out in the open, for everyone to see. It tucked in nicely with the rollbar.
Car: 92 Z28 Camaro
Got any pictures? Are you running a converter box for low Imp injectors, or is it built in to the XFI? I would like to mount everything in the factory location under the dash, but don't know how to go abount mounting the multiple items in the same location.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I mounted my ecu right below where the stock computer is. It was a nice fit and doesn't get in the way of the passenger's leg room.
Car: '85 TA
Engine: 350 turbo
At the time I didn't know if the stock ecu controlled anything, so I didn't want another variable if there were problems. I guess now, I just haven't gotten around to removing it.
Car: 92 Z28 Camaro
I wonder if there is a way to mount everything under the panel so that you don't show everything?
Originally Posted by JAYK2K3
i used the stock ecm bracket. but i just have the holley 950 ecm
Car: 25th Anninversary Z28
Engine: Pro Charged 355
Transmission: Built 700R4
How is it going. I just have to say that i love your car and that it is very inspiring for me to see an incredible build. Ironically enough i have pretty similar build going on myself. But mine is a little less extreme than yours. Anyway, i was wondering how the holley 950 commander is working with your build since you have a procharger? Are you able to tune it for a decent idle and drivability. It appears that are obtaining awsome HP & TQ numbers. Any feed back is greatly appreciated.
Car: 92 Z28 Camaro
I think it is a great system. I have the pro version with the wideband O2 on the passenger side and then a Innovate Motorsport Wideband O2 on the driver side and they both work great.With a solid roller cam I got the idle set at around 850-900 rpm
It sounds like you have car really dialed in. Are you using the inovative sports WB O2 for display only or do you have it tied into 950 for control? Are you happy with the overall drivability of the system "no dead spots in the tune"?
Car: 92 Z28 Camaro
The Innovate is for display/tuning only. I am really pleased with the overall system. I have yet to drive the car(got to get the ECM mounted) and a few things bolted in.
Excellent. If you dont mind, can i ask what you have invested in the Pro 950 & Inovative WB?
I am interested in the FAST XFI but it is kind of costly.
Car: 92 Z28 Camaro
If you had not noticed the car domain page motor pictures were from a Super Chevy Magazine Tech article (Nov,Dec 2005) Everything was sponsored.
Car: 92 Z28 Camaro
I was under my dash this morning and all I can do is shake my head and wonder where the hell am I going to mount 3 seperate boxes? I thought it would be perfect if I mounted them flush up against the firewall. But then you would have sheet metal screws protruding out of the firewall into the engine bay and well that looks like ***.
Any insight is greatly appreciated.
Car: '85 TA
Engine: 350 turbo
How about the oppisite side of the controller in the background? is it also supported and attached to something?
Car: 92 Z28 Camaro
Mounting the ECM in the location that you have placed it, are you able to reattach the stock plastic cover?
Car: '85 TA
Engine: 350 turbo
I'm not sure b/c I don't have that plastic cover. I don't think that it would fit over the ecm though as is.
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I might now actually re-mount mine like that, it'd be alot easier to access. Right now my Megasquirt is mounted on the firewall. On my car, where was some kind of floor fent or something that mounted the firewall right behind the heater box. I just took the vent off (I never use floor vents anyways), made a metal plate, put the gasket back on and screw it over the hole. The just mounted the MS to that. Out of the way and semi-accessible when I need it
Car: 92 Z28 Camaro
I'd really love to see pictures if you have any. This is the same way I think I may go. I have completely gutted the inside of dash so now there is not much to bolt to other than the frewall.
Car: 89 RS
if I remember Ill take some pics tonight or this weekend. It was about the only spot I could find where it was out of the way and yet still accessible
Car: 92 Z28 Camaro
Sweet! That would be greatly appreciated.
I have my XFI mounted in the kickpanel also. Its not secured though, just kinda laying there till everything is finished up.
86CamaroDan
09-29-2015 10:08 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
