Wrong ESC module?
Old 06-09-2008, 03:58 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Wrong ESC module?
I have a 1984 Trans Am. It had a carbed 305 H.O. originally. I bought the car a year or so ago, from a guy who had swapped in a 350 T.P.I.. 1988 I was told. He replaced the computer, and fuel pump, those are the only things I'm sure of. Since I've had the car it has been a real fight to get it running right. Things I've replaced: Fuel pump relay, MAF, CTS, Oil pressure guage, TPS, Coil, Distributor, Cap, Rotor, Plugs, Wires, Thermostat. The problem I'm currently trying to fix is no timing advance. I set it to 8 degrees btdc with the est wire unplugged (the timing mark jumps around by 2-3 degrees, only holds steady when car is in high idle) plug est wire back in and no change. No advance, no retard. The only thing left to replace would be the ESC module. My question is - Does anyone know how to tell the difference between a 305 and 350 module? The number on the module I have is HKM 882401 (Niehoff). The cheapest one I can find here in Missoula Montana is $85.00. I would hate to throw that money away if it is not the problem. Any advice/knowledge would be appreciated. Thank you, Sonny.
Old 06-09-2008, 04:01 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Wrong ESC module?
I don't think there is a difference. The ECM controls how much advance the engine gets, the ESC simply makes it happen.
Old 06-09-2008, 04:20 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
When I look the parts up at parts america they give different numbers between the 84 carbed and the 88 TPI. But the pictures are exactly the same. Not to mention the 30 dollars difference in cost. I read somewhere else that the 305 and 350 ESC will not interchange, but nothing on how to tell the difference. The niehoff model number on my current ESC does not come up anywhere.
Old 06-09-2008, 04:41 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
The ESC module is used to retard timing when knock is detected. If you are not getting knock retard then the ESC module/knock sensor is not the culprit. You'll need to datalog to see if there is retard, or, you could disconnect the module, ignore the code, and see if your timing is still jumping around by using a timing light. If no longer jumping around, reconnect the module and disconnect the knock sensor. If not jumping around then it's the knock sensor that's bad, else the module.
If you want to insure proper knock retard you should buy the proper module for your engine.
Old 06-09-2008, 05:06 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well the carb ESC will be different, the distributor is different. 84 will have the cap-in-coil HEI setup, 88 will have the remote coil. However the ESC between a 305/350 TPI should be identical.
Old 06-09-2008, 05:13 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Theres a difference in the 305 and 350 TPI ESC module, different numbers on them, and as same with the Knock Sensor, 305/350 TPI KS is different too, because they are tuned to the block size...
So if you got an 305 buy an 305 module and if you got an 350 buy an 350 ESC module, tpiparts sell them both..
Old 06-09-2008, 05:38 PM
Pop45398's Avatar
Car: '91 RS
Axle/Gears: 3:42
I think you are confusing EST and ESC modules. ESC modules are either mounted on the firewall or inside the MEMCAL but never in the distributor, that's where the EST module is found.
EST - Electronic Spark Timing - controls timing
ESC - Electronic Spark Control - for knock control
I should have mentioned earlier that the EST module is likely the culprit but by eliminating the ESC/knock sensor as the problem (which is easy to do) pretty much narrows it down to the EST module (or ECM).
Old 06-09-2008, 05:53 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Maybe I'm confusing you guys. I have no spark advance. I set the base timing, with the black/tan two wire connector unplugged. When I plug the wire back in the timing should advance right? Well it doesn't, it stays at base timing. I just replaced the distributor this morning and while the car doesn't seem to miss as much, the timing still does not advance as it should. Or at all for that matter. Hope that helps you to help me. Ask any questions, I will answer. Thank You, this site has been such a huge help to me with this car so far!
Old 06-09-2008, 06:42 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
First of all i think you need to find the correct connector. The set timing connector should only have one wire,a black and tan wire. Have you verified the check engine light is functional and no codes are saved in memory?
Old 06-09-2008, 07:30 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Yeah, you're right. I was thinking the ESC was the module on the distributor base.. Dang confusing acronyms!
Old 06-09-2008, 07:32 PM
Pop45398's Avatar
Car: '91 RS
Axle/Gears: 3:42
Easy to do, especially when there is only one letter difference and they both have to do with timing.
Old 06-09-2008, 08:59 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
The check engine light is operational. I get code 12 three times followed by whatever codes are stored in memory. Now....if there are codes stored in memory will that effect normal operation? If that is the case maybe that's my problem. But I thought that when the problem was corrected and the light turned off, everything would operate normally. As far as the set timing connector, in addition to disconnecting the two wire connector(which made no difference at all) I jumped terminals a and b of the aldl while the engine was running and It caused the timing to jump up about 5-6 degrees. Is that normal? Also when I rev the motor slightly the timing retards 6-8 degrees before coming back up to base. The motor that is in there now is the 88 5.7l TPI. And I think it indeed uses a two wire set timing connector.
Old 06-09-2008, 09:05 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Is the EST the same as the ignition module mounted on the Distributor that has one two pin connector and one four pin connector? Because that was just installed this morning with the new distributor.
Old 06-09-2008, 10:03 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Okay, I feel like an idiot, but hopefully learned something valuable here. I do have timing advance. I was disconnecting the wrong wires to set the timing. It is indeed a one wire connector black/tan. Thank you all so much for pounding your brains along with me here. If I run into any more problems I am thankful I have your knowledge and experience to rely on. Many many thanks! Sonny
End Thread.
Old 06-10-2008, 12:46 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Missoula Montana,
My home town, boy I'll bet its changed over all
these years
Still have the pulp mill odor?
Later
Old 07-31-2008, 07:36 PM
Chrisry1995's Avatar
Car: 89 Trans-Am
Engine: 5.7 TPI
Hey, did you find if the HRK 882401 esc module is for a 350? They are different from 305 to 350's I need one because I changed my 305 for a 350 and found one with hrk 882401 on it and want to know if that is for a 350. Do you know???
Old 08-01-2008, 09:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The correct ESC's are:
5.0L: HKM -2391
5.7L: HKR -2401
The HKR was also used on the 4.3L V6's.
RBob.
hectre13
Car Audio
26
03-03-2022 05:38 PM
InfernalVortex
04-20-2021 11:31 AM
sheachopper
07-31-2019 11:27 AM
dusterbd
09-29-2015 08:40 AM
tattmann
09-27-2015 05:20 PM
Quick Reply: Wrong ESC module?
