NEW adapter board for megasquirtII to 86-88 tpi cars
Old 04-29-2009, 07:13 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
bitchin news! A guy named Marc has designed an adapter board for directly connecting a megasquirtII to our factory wiring harness. no more splicing wires, custom wire harnesses, testing connections, etc. has tcc circuit integrated, directs pin 30 to the fan trigger for fan control, has ignition power ckt built in, knock circuit, etc. anybody interested in it? it requires a little soldering and a donor ecm case. the beauty of it is it looks like you have a factory ecm. i'm going to try to setup a little timer circuit to make my check engine light come on for a few seconds on startup so it looks right.
here's a few pictures of mine:
Old 04-29-2009, 07:58 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: NEW adapter board for megasquirtII to 86-88 tpi cars
fantastic, from where can i get it ?? with this stuff there is also no need to rewire HEI to control ignition ?? with this adapter how to connect WB o2 (i have innovate)??
best regards
Old 04-29-2009, 09:08 AM
thunder85's Avatar
Engine: 5.7L w/hsr
I cut the wire off my old narrow band and spliced that wire/connector right onto my wideband output wire. works slick and keeps the factory wires unhacked. I have an innovative LC-1 myself.
do not have to rewire anything in the ignition. I didn't do ANYTHING to mine... my ignition is all factory with no modifications.
Old 04-29-2009, 09:19 AM
WASyL's Avatar
superb, can You tell me how to get this stuff ??
best regards
Old 04-29-2009, 09:24 AM
thunder85's Avatar
Engine: 5.7L w/hsr
I havn't gotten his permission to post his contact info on here yet but I will PM anyone the information until then (he is selling them now).
Price for the bare board is the same as the TBI adapter board at US$35 ea. In addition you need to supply a donor ECM - it can be a '747 TBI ECM - you just use the case and the connector from the donor which is the same as the '165. The rest of the parts come from digikey and cost about $15. The assembly instructions are identical to the TBI adapter found on DIYautotune.
He's already talking to the folks at DIYautotune to have it sold on their site.
Old 04-29-2009, 09:31 AM
WASyL's Avatar
ok, but as i'm from europe not usa i preffer to get full kit ready to solder (or allready soldered and tested) as geting parts is hard for me and very expensive so i would rather pay to get one p&p, just reday to put my MSII into it.
best regards
Old 04-29-2009, 10:08 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Looks pretty good.
Old 04-29-2009, 05:51 PM
thunder85's Avatar
Engine: 5.7L w/hsr
damn.. i thought there would be more excitement about this... its freakin awesome in my book. for under 400 you can have a kick *** aftermarket ecu with no wiring or modification of the stock harness. plug this puppy in and no more burning chips... and you get realtime tuning and all sorts of customization possible.
Old 04-30-2009, 10:34 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Wow man! That is really impressive. Makes my MS install look like a turd in comparison.
Then again, mine was not a TPI to begin with.
What a sweet product. If I ever get another car, i'll be sure to buy one!
I'll also post it up on my forum.
-Brendan
Oh, and WAYsl, this is a better option by far then what we were discussing.
Old 04-30-2009, 10:43 AM
Toehead's Avatar
Do you know if it does knock sensing?
Old 04-30-2009, 12:05 PM
ls six's Avatar
Nice I have been thinking about the 411 / OBD-II swap but I havent looked into the advantages of MS vs 411.
Any opinions?
Old 04-30-2009, 12:25 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
this is awesome, i want to megasquirt my IROC sooooo bad... it really doesn't cost that much more than getting all the stuff to burn proms, but its sooo much easier to just plug in and flash it. i'll store this info away for the 383 build
Old 04-30-2009, 03:58 PM
thunder85's Avatar
Engine: 5.7L w/hsr
it does knock sensing... the circuit is built on the adapter board to bring the knock signal into pin pin 6.
i will probably be recording some video this weekend of the board, setup, etc.
anything in particular you guys want to see pictures of or have questions on?
Old 04-30-2009, 09:22 PM
efi-diy's Avatar
DIY Autotune will be carrying the board - available in about 4 weeks.
Old 05-01-2009, 07:45 AM
thunder85's Avatar
Engine: 5.7L w/hsr
sweet. they should offer a package... adapter, ms2 and lc1 wideband. thats all u need to swap the ecu.
Old 05-01-2009, 08:38 AM
Toehead's Avatar
Excellent. Those guys have a well-deserved reputation of being the best. I'm glad such a reputable place will carry the board
That's awesome about the knock sensing. That makes it a lot easier. I had to drill a hole to pass in my knock sensing signal line...
My proto area is getting full!
To all who are planning to use the hall input with the stock ignition and build your own, there is an incorrect resistor value that gives a little bit of trouble when it gets hot out and the module voltage drifts. I'm not sure if the value has been fixed in the kits, it probably has. Check it out here.
http://www.msefi.com/viewtopic.php?t=27509
Old 05-01-2009, 08:40 AM
Toehead's Avatar
I just checked it out , and the value is fixed in the manual after I made that thread. It's pretty cool to see something I noticed be implemented
Old 05-03-2009, 05:37 PM
WASyL's Avatar
true but price i was offered is high over than i expected + shipping and taxes
best regards
Old 05-04-2009, 08:44 PM
efi-diy's Avatar
There might be an opportunity for some creative folks to build and sell completed boards...
The assembly instructions are identical to the TBI board - check DIYautotune.com under adapter boards.
Old 05-05-2009, 09:05 PM
efi-diy's Avatar
They should be ready for sale in about 4 weeks.
Old 05-07-2009, 05:25 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Will this work with the harness from a 730 car? I don't want to run a whole new harness from another car so if it doesn't I might as well just buy their universal harness so that I don't have a nasty looking old harness running everywhere.
I already have the money sat aside for this so I am ready to buy NOW if possible. I'm getting anxious.
Old 05-07-2009, 01:27 PM
efi-diy's Avatar
Unfortenately the 7730 is a newer version of GM ECM than the '165 so this adapter board won't work the pinout is different. The 7730 ECM has a number of features like VSS interface that MS does not currently support. What could be done - a bit more work but cleaner would be to repin the needed inputs & outputs from the '730 harness connector into a '165 connector (easily found in a 88-92 GM TBI truck - its the same connectors). This way the VSS, speedo output and cruise outputs will still function from the '730 ECM and you won't lose thse signals, then use the adapter board to plug in your MS. You might have to splice the ign. +12 and ground wires though.
The '7730 adapter is the next in line to get done but its at least a 6 months out as the VSS function needs to be implmented.
Thanks for asking.
Old 05-07-2009, 02:34 PM
AmorgetRS's Avatar
That is very cool. Is there a reason it doesn't work with the 89s?
Old 05-07-2009, 11:50 PM
efi-diy's Avatar
'86 to '88 TPI use the '165 ECM and the '89 to '92 use the '7730 ECM totally different electrical connections.
Old 05-08-2009, 12:41 AM
AmorgetRS's Avatar
1990 was the first year for the 730 in a Thirdgen. 165 was used in 89.
That is unless the Schucks website is wrong, but I don't believe it is:
http://shop.oreillyauto.com/ProductD...pe=248&PTSet=A
Check the years it fits.
Old 05-08-2009, 01:11 AM
efi-diy's Avatar
Hmm
Thank you for the correction, can you update the topic header to '86-'89.
Marc
Old 05-09-2009, 08:06 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
but what does it all mean basil? i'm interested when ya get the 7730 lined out, what would be really kick *** is if ya could do a 7730 swap from a 165 without harness change.. if it's not impossible it would be awsome!
Old 05-10-2009, 01:37 AM
efi-diy's Avatar
When the adapter gets done for the '7730 harness it will be to plug MS the stock 7730 harness complete with speedo and cruise control support.
Old 05-11-2009, 10:36 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
so will this keep the MAF or can i do away with it with the megasquirt and this adapter board?
Old 05-11-2009, 10:58 AM
WASyL's Avatar
with megasquirt you can throw away MAF as MSII has built-in MAP sensor
best regards
Old 05-11-2009, 11:32 AM
Street Lethal's Avatar
Originally Posted by efi-diy
The '7730 adapter is the next in line to get done....
Nice!
Any plans for the '7148 (TTA) later on....?
Old 05-11-2009, 02:18 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
best regards
thanks, i knew it had the built in MAP just wanted to make sure that i was gonna be kosher to get rid of that thing
Old 05-11-2009, 02:25 PM
WASyL's Avatar
yes "that thing" will be no more useful, maybe except as and way to earn couple of bucks on ebay
best regards
Old 05-11-2009, 06:48 PM
efi-diy's Avatar
If you every did want to revert to a MAF MSII supports Ford type MAF sensors.
The adapter boards are well under way.. stay tuned to DIYAutotune's web page for availability.
Old 05-11-2009, 09:40 PM
efi-diy's Avatar
Originally Posted by Street Lethal
Nice!
A couple of questions...
1) is the '7148 the same physical size and shape as the '165/747 ecms?
2) do you have the harness connector pin out for it? If you do email it or a link to me.
If the footprint is identical to the '165/747 ECM's and the pin out is close to the '165 this could be a quick one to do. I'd need a beta tester that has a good amount of tuning/troubleshooting experience as I don't have a turbo V6 to go try it on.
PM me for email addy.
Old 05-17-2009, 07:07 AM
WASyL's Avatar
hello, any news when it will be available ??
best regards
Old 05-17-2009, 11:52 AM
efi-diy's Avatar
best regards
Within 10 days. The boards are enroute to DIYAutotune.
Old 05-18-2009, 02:19 AM
WASyL's Avatar
can't wait to get my hands on it
best regards
Old 05-19-2009, 09:27 PM
efi-diy's Avatar
I'd send DIYautotune a query on the adapter board....
Old 05-20-2009, 02:15 AM
WASyL's Avatar
aaa it's allready there, i'm just placeing my order
best regards
Old 05-23-2009, 12:04 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Are you still thinking its going to be around 6 months or so on the 7730 adapter? I am assuming it is, but I am wishing for some good news...
Old 05-26-2009, 09:13 PM
  #42
efi-diy's Avatar
Most likely yes .. unless you can write embedded "C" code... with our short summer here its hard to get programming done "after hours" - the basic board is not the hold up. The VSS interface needs an extra processor to convert the VSS signal into a speedo and cruise control signal. The hardware to do this could be done soon but these 2 outputs would not function until the code got written.
Old 05-27-2009, 02:31 AM
  #43
WASyL's Avatar
damn, i paid over 30$ extra for 3 day delivery to Europe location shipping, and what i recieved was TBI adapter not TPI adapter board
now i'm waiting for any response when i'll recieve proper one and if i'll get any compensation for paying extra to get not what i ordered
Old 05-27-2009, 12:00 PM
  #44
Toehead's Avatar
The DIY guys run a tight business. They will make it right.
Old 05-27-2009, 04:35 PM
  #45
WASyL's Avatar
i know, but i wantet to get it as soon as possible and paid for that extra 30 bucks and now i have to wait until tuesday anyway i was waiting for this adapter like for christmas gift
Old 06-05-2009, 06:19 AM
  #46
614Streets's Avatar
Well crap I have cash in hand and need something uncomplicated for my 1989. Go figure.
Old 06-05-2009, 06:42 AM
  #47
WASyL's Avatar
MS with adapter is not complicated if You use it with WB 02
Old 06-06-2009, 09:22 AM
  #48
Toehead's Avatar
How's it going???
Old 06-06-2009, 03:31 PM
  #49
WASyL's Avatar
still waiting for adapter delivery company has lost the package and can't find it, this is what i was told today. And what about AFR, VE and ignition table that You said You can give me ?? that would save me some time on beggining of tuning
best regards
Old 06-06-2009, 11:32 PM
  #50
Toehead's Avatar
I'll get it tomorrow
I'll export the table so you can just reimport it. I'm afraid i'm running quite a few code versions behind so my .msq won't really do you any good !
Quick Reply: NEW adapter board for megasquirtII to 86-88 tpi cars
