Help ID this section of ECM buring out
Car: check
Engine: check
Transmission: check
Re: Help ID this section of ECM buring out
U26 is a quad driver. This chip drives the A/C compressor clutch relay, TCC lockup solenoid and the ALDL serial link.
Need to check the coil resistance and wiring for those three items. Odds are the ALDL is OK, unless you tied pin E or M to +12 volts or something.
RBob.
RBob.
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Thanks for the help! I understand what you mean by check the wiring but am lost at checking the coil resistance. And when you say tied pin E or M to +12 volts you mean I one of those wires is now getting power and its not supposed to?
Car: check
Engine: check
Transmission: check
As for coil resistance, usually 20 ohms or higher. If it is too low then the high current fries the quad driver. It is just like putting +12 volts right to the driver, it won't like that. The outputs of the quad drivers pull low to ground to turn devices on. So grounding the output won't hurt it.
But if a coil is shorted, then the driver fries. Odds are either the A/C relay is bad, or the torque converter solenoid (TCC) is bad. That one is inside the tranny above the pan.
Note that bad wiring can also cause this. It may be that the wire insulation at the connector is damaged and the wires are shorting together.
RBob.
efiguy
09-27-2015 01:30 PM
