computer and eproms problem
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
i have a 1986 camaro ,i took it to a shop to have the new updated eproms put in, well the people at the shop toll me that the new eproms fried the computer and the new eproms ,so i asked them did they unhook the battery they said that they did'nt have to ,when it said on the computer to unhook the battery .now my question is since it fried the whole work their do you think it hurt anything else like the wireing or do you think just replace the computer and eproms and unhook the battery will it run again ,just need someone esle input on this . thanks for any input done had the car completely restored
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: computer and eproms problem
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
i cant say forsure that s what caused the computer to get fried ,i think it was where they didnt unhook the battery ,it was clearly marked on the front of the computer (disconnect the battery before installing )i guess what i am asking what othe damage could it have done ,like the wireing or anything else
https://www.thirdgen.org/forums/dfi-...aro-eprom.html
you never answered the questions, I have a good used 1227302 ecm but I need to know what the letters on the eprom's you have to see if you are even using the correct eprom hnj ? .
I swapped eproms 100 times with battery connected-ign off. Never caused any damage. In fact I put eprom in 180d off and I dont think it even damaged the prom. Cant rememer on that one as was 5 years ago.
Possible the prom was wrong one and that caused damage? Not sure.
Swapping ECU in out, the battery I would disconnect
It looks like the 1227302 ecm started with the bcc hnj 16055624 and was superseded to ajuc 16080006 to ambf 16087038. this looks to be the best deal for you I don't have the ambf.bin to burn one for you. I have no idea what the p/n 1603659 you purchased.
http://www.ebay.com/itm/86-89-Camaro...4#ht_549wt_827
