"PIggyback" computer for fuel enrichment with Turbo?
Old 12-04-2001, 02:27 PM
Damon's Avatar
I was gonna post this in the Power Adder section but it's really more appropriate to post it here, I think, since I already know how to put all the hardware together, I jsut need to figure out the electronic side of the project.
I'm trying to figure this out for my brother's 86 Fiero autocross car with 3.4L Quad Cam motor out of a Lumina Z-34. Physically installing a turbo system (single T3/T4 hybrid, most likely) is not a problem.
Getting fuel enrichment worked out so the pistons don't melt down, not so easy.
I was thinking along the lines of a 2-bar MAP sensor, bigger injectors and then let somoeone else reprogram the stock ECM/chip for me. Then my brother suggested looking into buying a "piggyback" computer or something like that, installing a couple of extra fuel injectors into the intake, and only kicking them in when the motor goes into positive boost.
We will be increasing the engine's output from about 220 HP now to roughly 300.
I'm looking for suggestions (not necessarily limited to the above 2 ideas) from people who have actually done stuff similar to this before. I'm trying to get this project done in a quality way, but quickly, cost effectively and I don't give a rat's *** about the bits-and-bytes of it. I just want the results.
Suggestions very much appreciated.
Old 12-05-2001, 03:39 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
A lot of companies have produced add on injector kits with seperate controllers for them.
A lot of turbo Buick guys are using them with one injector.
I think A.T.R. http://www.atrperformance.com and Casper's http://www.casperselectronics.com/ make or sell them.
Here is an alternative way to inject extra fuel from a GN guy, http://www.gnttype.org/techarea/fuelsystem/7th.html
You can also get them with more injectors. Paxton http://www.paxtonauto.com was, and might still be making one for TPI/LT1 type throtle bodies that used three injectors.
Carroll Supercharging http://www.carrollsupercharging.com/ makes some they call "Superfuelers" that are worth checking out.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited December 05, 2001).]
Old 12-05-2001, 05:57 PM
Damon's Avatar
Thanks for the info. I will check them out.
Old 01-02-2002, 05:30 AM
IROCKZ4me's Avatar
Oops, I forgot about EFI Systems. Thats pretty bad since I have one of their PMS piggyback ECMs that they used to make for GM EFI setups. They don't make the PMS for GM apps any more, but they do make a "secondary injector driver" for add on injectors like the systems I posted above. Info is on this page: http://efisystems.com/sid.htm
Old 11-27-2016, 08:56 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: "PIggyback" computer for fuel enrichment with Turbo?
Dead thread, but right idea, if cheap enough.
Additional Injector Controllers are still a thing, I'm looking into one that runs $295, which is cheaper than a tune for an LSx, as it should be, but what about a MegaSquirt type DIY controller?
I found where some ricers claim to have done it on 2.0L 4s, but that leaves no baseline map for a 700 HP 4.8L, and an AIC can't pull timing.
Old 12-07-2016, 10:19 PM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
A handful of forced induction members are running Megasquirt.
I don't know what your last sentence means.
-- Joe
Old 12-08-2016, 06:03 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
He thinks adding an injector driver will take care of fueling for a turbo'd stock motor. Trying to save 100$ instead of doing the right thing and having it properly tuned. This is not the correct way of doing things. The driver is not an ecm which is tuned to supply fuel in the same sense as the stock pcm
9192camaro
16
02-03-2019 12:21 AM
Azrael91966669
25
06-20-2017 04:04 AM
sweet_87_iroc
09-25-2015 10:01 PM
theurge
08-21-2015 12:46 PM
Bryan F
08-18-2015 02:28 PM
Quick Reply: "PIggyback" computer for fuel enrichment with Turbo?
