Trying to troubleshoot possible ECM problem
Old 05-01-2016, 07:08 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
Not sure where to start...
In a nutshell, I need to find "the purple wire to ECM" ...
One issue I definitely have is a code 44= lean exhaust indication. Following the troubleshooting flow chart, my dwell still does not read 50* with engine at part throttle and choked. If you can see the pic... I am not sure how to proceed... I have a multimeter and can set it to 20v... connect to + batt. terminal... but what is the purple wire to the ECM?
thanks for reading,
J.
Old 05-02-2016, 07:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Trying to troubleshoot possible ECM problem
It is the O2 sensor wire, stock location is drivers side exhaust manifold.
RBob.
Old 05-02-2016, 06:30 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
So I connected my voltmeter from the O2 sensor wire to the + terminal, and then checked the dwell. Dwell needle moved back and forth from between 20 and 40.
"Check for an open from ECM term. 14 to ground"... Folks, I have no idea how to do this. Sorry if it's a dumb question..
Old 05-05-2016, 09:01 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Picked up a new O2 sensor- will try that this weekend..
yevgenievich
Exterior Parts for Sale
68
11-25-2016 02:42 PM
89irocz355
18
04-11-2016 10:17 PM
erik69&85
04-03-2016 01:33 PM
89TA WS6
04-01-2016 09:40 PM
krisb410
03-17-2016 05:51 PM
Quick Reply: Trying to troubleshoot possible ECM problem
