Wide Band and 7727 ecm
Old 11-26-2016, 11:13 AM
eutu1960's Avatar
Car: 90 C4
Engine: 385 SBC ProFlow Intake
Transmission: Auto 700R4
Axle/Gears: 3.07
how do you go about wiring up a wide band o2 to data log in Tuner Pro, I have a 7727 ecm and I am looking at this wb o2 .
https://www.amazon.com/AEM-30-4110-U...14YQVMHSDEPJX8
I did find a pdf on how to wire it directly to the ecm but would rather not do this, I read somewhere that I could yous the input for the oil temp sensor, but I would like to just splice into the aldl connector if possible.
link to pdf. http://www.gearhead-efi.com/Fuel-Inj...9&d=1477059122
Old 11-26-2016, 01:45 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: Wide Band and 7727 ecm
Does tuner pro have custom inputs through ALDL? If not, it won't work. Tuner pro needs to know to pull the data from the pin.
Don't know why you're against hardwiring to the ECU. It's easy and works like OEM.
Old 11-26-2016, 01:50 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
I plan on only using the wb o2 temporary for tuning purposes only, then removing it afterwards, I dont like the idea of messing with the ecm so I would rather find a another way.
Old 12-01-2016, 08:21 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Assuming you are using $8d in the 7727, use S_AUJP v5. All the work is done for you and the AEM WBo2 is directly supported to report AFR. Here:
https://www.thirdgen.org/forums/diy-...available.html
Old 12-01-2016, 08:51 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
Ok thanks when I have some time I will look through S_AUJP v5.
