MEMCAL and ESC
MEMCAL and ESC
Hey everyone. I am new to this board and have some TBI swap questions.
I have a harness for a 1227747 computer with the ESC module in the wire harness. I also have two 1227747 computers with EPROMs. I haven’t purchased my EPROM burning hardware yet and I want to go with an EEPROM. I recently purchased a 16197427 computer from a 95 350 truck with the MEMCAL and built in ESC.
Can I get an EEPROM for the 16197427 and use it with my old style harness and kill two birds with one stone and eliminate the external ESC and the need for a UV eraser?
What EEPROM should I use if I can use one? Or, can I get an adapter to go from the 1227747 EPROM to a MEMCAL and use it that way?
Are there any drawbacks tuning wise to using the less popular 16197427?
1 Post
Car: An Ol Buick
Engine: Vsick
Re: MEMCAL and ESC
Other then dropping all the tranny diagnostics, and VSS I think it would be a novel idea.
Just contact Moates for the adapter and EEPROMs if you can get around the 427s issues.
Thanks for the reply.
I am running a non-computer controlled tranny and no speed sensor, for now anyways, so I will need to eliminate all of that. Is it likely that I will be able to disable that in the PCM?
88SS6SPEED
11-11-2015 07:05 AM
