fan control...A/C pressure switch..two fans
Old 05-31-2004, 08:19 PM
91L98Z28's Avatar
Car: Z28
does anyone have a copy of a page from a service manual for a car which uses '730 which has two computer controlled fans?
based on the information here I jumped BD12 to F8, which puts the ECM's fan2 output on the same line as the block coolant temp switch and A/C overpressure switch. Which means that whenever the ECM grounds fan2 (to turn it on based on my temp settings), it's going to see an A/C overpressure signal as well. the logic this invokes in the code (around LD362 in ANHT hac) is such that IF you turn the AC on, and IF fan2 gets turned on (for any reason), the ECM logic is going to latch fan1 on until the AC is turned off, and fan2 is going to get latched on unless VSS indicates a speed higher than the fan2 allowable speed w/ AC on.
I'd like to see how a two-fan 730 application is wired to see if there is a way around this, or if the logic in the code is different (presumably a non-$8D mask)
Old 05-31-2004, 10:16 PM
91L98Z28's Avatar
Car: Z28
i asked too fast.
this had everything I needed:
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227730/
91L98Z28
Southern California Area
09-19-2015 09:35 AM
64goatman
09-09-2015 01:09 PM
85Special
09-03-2015 04:21 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: fan control...A/C pressure switch..two fans
