Tuning with the EBL
#3751
Re: Tuning with the EBL
Search by my name and then keyword "proportional". Quite a few show up. I will check my current EBL.bin ( hopefully tomorrow) and report the changes I made from stock LO3.bin on that subject. Keep in mind I have 75 lbs at 21 lbs FP currently. Also do same search just use RBob for poster not thread starter for proportional and many will show.
I found this response from RBob:
And one of the proportional gains tables. I usually reduce the one that has larger values in it:
PRP - Gain vs O2 Error
PRP - Gain Muliplier vs Airflow
So possibly only those two to change?
Read this a few times!
https://www.thirdgen.org/forums/diy-...ng-points.html
#3752
Ronny,
I locked BLMs when I used a 7747 pre:EBL because the baud and BLM update rate was soooooo sloow. The INT changed faster.
#3753
What would cause a lean situation right after start up and when going under load first taking off (manual). It does it when motor is cold. Mainly in the mornings or after its sat for a few hours.
When it was warm outside it would only do it for the first block or so away from my house. Seemed like once I ran it above a certain rpm/speed it would then not do it at the next stop sign. Now with it being colder in the mornings it is doing it even longer. Noticed this morning it did it the whole way to work (not even .5miles but has 6 stops). Used to when it was warm outside temp I could make it to the 3rd stop (Market St.) and it would be fine when I went to continue.
At first I thought maybe my afr open vs cts was off. But it idles rich when started cold as it is supposed to. Its just going under load that causes it to go really really lean. It pegs out my WB Gauge and barely keeps chugging.
#3754
Car: 1988 IROC-Z Convertable
Engine: 350 Cam, Heads, Heders...etc.
Transmission: 700-r4 "Raptor"
Here are some post I chopped up for reference: Might cut down on the searching some.
Smooth idle in open loop and surging in closed is usually due to too much proportional gain. Work with the gain table and value:
PRP - Prop Gain Offset for Idle
Likely need to be reduced.
RBob.
It looks as though the prop gain is a tad high. Also, at the beginning the VE% is jumping a bit. This is in the 00:05:37 block. There may be too much of a jump in VE% at that point in the table.
As for the prop gain I would change this table:
PRP - Gain Multiplier vs Airflow
At the airflow shown in the data log: 38-40 gms/sec. Reduce the values at that area by 10-15%. See if that helps steady things down. The WB shows the actual O2 swing which is quite high.
RBob.
I don't mess with the prop duration too often. Mostly change the proportional gain. Then once the gain is low enough for a little rich/lean, if the INT starts to swing I'll slow that down.
RBob.
Originally Posted by gofast51
In one of the threads I was reading it was mentioned that RBob had written a paper on this subject. Where might we be able to find it? I did a search on here but didn't come up with anything. I think a reprint might be appropriate for this subject as it seems to come into play with the EBL. At any rate I would like to read it for educational purposes as I don't think I'm in a position to mess with it yet.
Check the tuning Book up in the stickies. Under the 8063/8746/7747 ECM, fueling I believe.
RBob.
I usually start with reducing the Gain multi vs Airflow. If the values become small (large injector flow rates), I'll then reduce the values in the gain vs O2 Error table. With this table I'll do an across the board percent reduction in values. This is to maintain the same shape to the table.
Then to fine tune use the gms/sec flow rate from the data log to define which are to change. This is with the Gain multi vs Airflow table.
Sometimes the INT starts to fight with the prop gains. Slowing down the INT update time helps in this regard. It can be helpful to slow the INT update down when doing prop gain cals. Just to keep it out of the way.
RBob.
A lot of the ideas that are being kicked around I covered in my first port (#3 of thread). It would be helpful to reread that post.
As far a tuning in the proportional gains tables, I go by exhaust sound and the INT. But first, I rough them in by changing them by the same amount of change in injector flow rate. If a larger displacement engine is in place, say a 383, that too needs to be taken into account.
It is all about ratios. Double the injector flow and need to halve one of the two proportional gains tables. The two tables get multiplied together, hence the need to only halve one of them.
If at a steady state cruising speed the exhaust sounds like there is a bad u-joint, too much proportional gain. Look at a data log and look at the airflow at that time (gms/sec). Go into the proportional gain vs airflow table and reduce it at and around that air flow.
Flash and re-test.
As for using the INT, if the INT is rapidly increasing and decreasing there is too much gain. Would likely see this in the bad u-joint example.
A slowly increasing and decreasing INT means that there isn't enough gain. This forces the ECM to use the INT to create cross counts (O2 signal). This causes an overshoot of the AFR. Which can be heard in the exhaust an oscillation. Can also cause the engine RPM to follow the AFR change.
RBob wrote " If the idle speed has been increased you should also increase the RPM threshold for the BLM idle to decel switch over (BLM - Idle Cell RPM Threshold)"
#3755
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
i need to save your post bphage, thanks for putting that into compact form!
on a side note, EBL is brilliant but imho it lacks a good manual. a wiki or the like would be really helpful for all of us, from rookies up to the veterans helping here. don't get me wrong, there's a lot of information out there and Bob is always helpful and approachable. i just think everybody would have a better time when not pointing out the same points over and over again. the information is just really spread out.
now my question
i recently noticed that my L03 when cold puts a lot of drag torque on the drivetrain in DFCO.. is there any way to relieve this condition? i know you can "adjust" DFCO drag torque by the IAC steps that are commanded during DFCO. but i'm afraid for this issue, a DFCO IAC steps vs CTS would be needed and i would probably be the only guy using this, but still just an idea.. probably most people just have DFCO disabled up to 50°C CTS or whatever the stock setting was. i have set it to like 20 or so for so long i already forgot.. anyone else?
now my question
#3756
#3757
Engine: LS1 / L03
that's exactly what i think, all the information is out there and people, first of all RBob of course, know their stuff but it's just poorly organized i always found..
i never understood how Bob is keeping up the good work with so many people asking stuff that has already been asked a 100 times before, not only in this thread but i can only guess at the amount of time he spends typing emails in a day
besides, a wiki is a really nice way of organizing a community's knowledge, which is definitely something that applies to not only TGO but also quite some other forums and plattforms the EBL has been becoming more frequently used. so, not just RBob spreading some of his brilliant wisdom but more of a knowledge base uniting all the different inputs from multiple brains
#3758
Which of these AE tables needs to be changed to ad fuel at wot "pump shot"? or do I add subtract to all of them and in what order. I am running a tbi on a carb manifold
AE-MAP filter
AE-MAP PW
AE-TPS Filter
AE-CTS multiplier
AE-RPM multiplier
AE-MAP filter
AE-MAP PW
AE-TPS Filter
AE-CTS multiplier
AE-RPM multiplier
#3759
Car: check
Engine: check
Transmission: check
The MAP and TPS PW tables are used to control the volume of AE. Higher value, more fuel.
The MAP and TPS filter tables are used to control the duration of the AE. A lower value is longer, but also slightly more volume.
The CTS multiplier adjusts the volume of AE based on engine temperature. Higher value is more AE.
The RPM multiplier adjusts the volume of AE based on engine RPM. Higher value is more AE.
RBob.
RBob.
#3760
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
that's exactly what i think, all the information is out there and people, first of all RBob of course, know their stuff but it's just poorly organized i always found.. i never understood how Bob is keeping up the good work with so many people asking stuff that has already been asked a 100 times before, not only in this thread but i can only guess at the amount of time he spends typing emails in a day besides, a wiki is a really nice way of organizing a community's knowledge, which is definitely something that applies to not only TGO but also quite some other forums and plattforms the EBL has been becoming more frequently used. so, not just RBob spreading some of his brilliant wisdom but more of a knowledge base uniting all the different inputs from multiple brains
#3761
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
so im sure its here but I cant find it.. maf car uses a esc with knock sensor,, ebl flash with port mod switches to map,, map has no esc correct(in ecm). does it stay plugged in whats up with this.. after the pin moves of course.. leave it plugged in.. in place? some are 5.0 some 5.7 whats the low down on this?
#3762
Car: check
Engine: check
Transmission: check
Dependent upon which EBL system is being used the "EBL Flash" may be "EBL P4 Flash" or "EBL SFI-6 Flash."
RBob.
#3763
Car: check
Engine: check
Transmission: check
The knock sensor and ESC module differ between a 5.0L and a 5.7L engine. Changing the sensor isn't as important as changing the ESC module (knock filter).
RBob.
#3764
Car: 1983 G20 Chevy
Transmission: 4L60
Got my hands on an EBL Flash today that belongs to a local guy. The EBL easily handled a Comp 269 roller cammed flattop piston 350 Vortec in a GMT400 truck. Played with the tune for a few hours and got it running pretty well for him. Last time I adjusted the minimum air rate, fixed a couple of vacuum leaks and tried to fix a connectivity issue that was a bad cable. With a working cable, today I started over with a fresh, untouched LG4 VE table, Vortec spark map and corrected the BPWC and Initial timing constant values to match the setup, then performed a few VE learns, smoothed out the VE tables, adjusted the open loop air/fuel table and highway cruise. I tried enabling closed loop but never could get it to transition. I think 02 sensor location is the issue, so I left it a touch rich, about 14-14.5:1 in open loop and 16-16.2:1 in highway mode and left it in open loop. Seems to run very well.
#3765
Is your O/L AFR Bias constant > than the target AFR at the Coolant C for Clsed Loop?
#3766
Car: 1983 G20 Chevy
Transmission: 4L60
Honestly the calibration was done on his laptop and not sitting in front of me. I can get a copy and look. His truck has a vortec manifold and he tapped the EGR fitting for an 02 sensor. The sensor sits up inside the manifold out of the exhaust flow. I think it is 02 placement more than anything.
#3767
#3768
Boost control with the EBL-P4... which area in the XDF can I utilize, was thinking of the charcoal canister stream mainly because the connector lines up right where I need it to. Is there a way to get it to work properly, or should I just go with an aftermarket EBC?
#3769
Car: check
Engine: check
Transmission: check
We haven't added boost control to the EBL P4 yet. The EGR output (E9) is what we are planning to use for the WG control. Easy enough to move the CCP output terminal/wire to that location.
RBob.
RBob.
#3771
Engine: LS1 / L03
Nice...!
I haven't looked into it, but is BPC currently supported with the SFI6?
#3772
Car: check
Engine: check
Transmission: check
The RJC unit gets it's boost reference from the turbo outlet. This produced less under and overshoot.
The good news is that the EBL P4 now also has alky injection control. Just need the mechanical parts of the system and a Mopar fan relay module as a pump driver.
RBob.
#3774
Engine: LS1 / L03
BPC - Boost Pressure Control, sorry for using an ambiguous acronym here
Interesting point on what you say about the control input signal from MAP vs. compressor outlet nipple...
#3775
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
A tad "out there" yes. Sounds like something I might do !
I'm curious as to whether it responds at all, and how fast, though I realize that Fast355 doesn't have the vehicle readily available.
If it's too far out of the flow, that could explain a failure to transition.
#3776
Originally Posted by RBob
I used an RJC unit for a while with good results. Haven't had much feedback from the others on the WG control in the EBL SFI-6 ECM. Myself, with the large-by-huge FMIC and charge pipes, there is a lot of lag in the system when looking at intake manifold pressure for the control point.
RBob.
RBob.
#3777
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
hi I have a bit of an issue...my 90 gta with ebl p4, I have a problem when I let the car sit for more than 2-4 days I have to crank it for a bit then let it sit for few min, then crank it again and it starts....when cold.
now if I use it all day....then go to start it next day(car cold again after being parked for over 14 h) it starts just fine.
the problem only occurs when car sits more than 2 days...whats up with that?
fuel pump is new...aeromotive 340l...car has mild cam, tfs heads, hsr intake 58mm tb, eagle 383 rot assembly 10-1 comp
#3778
My habit is to turn the key on, and listen to the booster pump. After a second, or two, or maybe four, it begins to sound loaded, and I know that fuel pressure is up. THEN I turn to crank. The engine might turn 4 compressions before firing. If it's been parked for a month, maybe it turns 8 compressions, or two full rotations, before running.
It never fires but not start. Never.
Normally, on a warm engine it doesn't get past the second compression before it's running.
I might suggest try key-on, wait 5, then crank and see if it's different. You may just need a second or four for the fuel to come up to pressure.
#3780
Car: 1990 gta
For me, the stock TBI pump can't develop the pressure. ( in fact, stock has a built in relief at 15 PSI. ) Therefor, I have a Ford in-line booster pump.
once car starts...maintains 12.7 to 13.2 afr until warm when leans out to 14.5 at idle.
it use to have a burned chip before I installed eblp4 it would start fine even if I didn't start it for few weeks, same mods as well.
im just wondering if im missing something.
on the good note the chip I had before was done by local performance shop...made 418whp/512wtq...just dyno it yesterday with my tune on the ebl 434whp/544wtq...lovin the ebl.
#3781
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
What could cause a dead spot in my rpm range at around 14-1600 rpm it just don't wanna go like its flooding out also my VE is really high here .. My wideband took a crap so I'm waiting for funds to fix that but it don't matter what I do in that range even if I mash to floor sounds like it's bogging out n just won't go till it gets to 1700 then takes off
Also if I stab throttle wants to sputter but if I ease into the throttle it goes pretty hard till I reach about 80% throttle then it just goes downhill
And how can I lean it out a little at cold cts temps right after initial firing until it gets up to say 130*
#3782
Car: check
Engine: check
Transmission: check
Which intake manifold are you using?
Hesitate is lean, chug/gurgle is rich. Either way need to adjust the AE tables. A dump of the data log is helpful as there is AE information in it.
Open Loop - AFR Multiplier vs CTS
As it is a multiplier, a more negative value is richer. reducing the values toward 0 will make it leaner. Can also make it even leaner by going with positive numbers.
RBob.
#3783
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Probably need to work on the spark advance (SA). Which intake manifold are you using? Sounds like the fuel delivery can't keep up. On the throttle stab does the engine hesitate and possibly backfire out the intake? Or does the engine chug and/or gurgle? Hesitate is lean, chug/gurgle is rich. Either way need to adjust the AE tables. A dump of the data log is helpful as there is AE information in it. This table: Open Loop - AFR Multiplier vs CTS As it is a multiplier, a more negative value is richer. reducing the values toward 0 will make it leaner. Can also make it even leaner by going with positive numbers. RBob.
Also intake has no air gap and heat crossover is blocked off ... Also has been fully ported and polished on all short side radii
#3785
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
It does the same thing at that 1500 rpm area but in first n second gear it will pull through it only does it under load .. Say cruising at 40mph 1500rpm and if I try to accelerate and load goes over 50-55 kpa it just don't do nothin setts at 1500 an gurgles ... Also my PE sA vs gear are all 000
Also VE is really high in this area .. But learns show only -5
#3786
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
here is my current bins and datalog . if anyone could help me out or has time to modify and resend i would b very thankful! if anyone can get this thing running like it should ill paypal u $ for ur time .
thanks all fellow thirdgeners!
Nate
nathanjagness@gmail.com
if u need info on the build just ask or go to my build thread @ "LO3Rebuild(HP Estimates)"
Nate
#3788
Car: check
Engine: check
Transmission: check
In the CSV file look at records 10,711 through 10,750. The BLM is bottomed at 118, the INT is headed downward, and the NB O2 value is in the high 900's. It is rich.
RBob.
#3789
I finally had the time to rewire and install the AC Delco narrow band.
Left the wide band at stioch 14.7 and just look for 14.1
Seems considerably better than the Bosch however:
Still on the rich side, RBob I did notice on the O2 swing it spends more time on the rich side than lean which brings the avg AF to the richer side.
Is there a table that would effect that?
And I also tried to adjust closed loop target leaner along with O2 tables, but it still just adjusts blm to bring it back to where it was-can't figure that one out.....
Here it's at 15 and 25mph on a dyno under load. CO was at the limit of .56, going for recheck because the gas tank didn't hold pressure-hose fixed now. Was afraid it would nudge over the limit on recheck so dug back into the O2 mean/rich/lean and at idle tables.
With this narrow band sensor I did get it to change to where I wanted it. ( I have an old 4 gas bench from pre dyno smog days to check tail pipe numbers, so can check tailpipe numbers without NOX).
But I had to adjust the O2 mean all the way down to 250mv with plus/minus 50 to obtain 14.5 to 14.7 by CO numbers at tailpipe. (0.2 to 0.13 CO)
I saw one post where someone had to adjust the MV mean all the way down to 100 I believe it was.
Question is how can a narrowband be off by that much calibration? On stock cars you just throw in a new sensor and it's good..........
Those tables are there so we can adjust, but do we really have to adjust for every narrowband to pass smog-just doesn't make sense compared to stock setups????? Can't wrap my brain around this one.
#3790
Slightly longer version, perhaps unburned fuel, which would leave a surplus of unburned O2, which would make a narrowband think it's lean and richen it up.
CO is, of course, unburned fuel, but it's vaporized at least. Your 4 gas *should* be able to detect that, but a narrowband won't.
#3791
This brings up a quick question for RBob and others. If you have flipped over from Bosch to AC Delco O2 sensor, or Denso for that matter, does that require a change in the O2 windows or does it not matter? I know that when I made the swap to ACs, my BLMs appeared to be leaner on the next scan where I had thought I reached close to a 128 avg.
#3792
Short version, it can't !
Numbers for smog with mean at 450MVs.
15mph hc-71 (max-90) co-0.56 (max-0.56) nox-147 (max-774)
25mph hc-41 (max-72) co-0.42 (max-0.42) nox-127 (max-655)
and with mean adjusted to 200mvs.
15mph hc-65 co-0.36 nox-216
25mph hc-36 co-0.19 nox-178
So doesn't seem like excessively high HC to explain it either.
#3793
I know this is jumping back a ways-It's been running good-but it's Kalifornia smog check time again.
RBob-any thoughts on this?
Are there other tables that could throw this off?
#3794
#3795
Car: check
Engine: check
Transmission: check
Change the oil & filter and install a new set of spark plugs. That will help clean up the emissions.
RBob.
#3796
It seems I'm not the only one that has had to adjust the mean/high/low O2 Mv way down to obtain stioch-14.7.
My understanding was that 450mv will be 14.7 with all narrowbands.
Going to the ac delco O2 sensor did get closer than the bosch but was still running rich.(all blms already at or close to 128s)
(does have new oil/filter/plugs)
Thanks for any insight.
#3797
The issue I am puzzled about is the apparent calibration of the narrow band O2 sensors.
I know I have some inaccuracies in my explanation. No doubt RBob will add his clarifications to it.
#3798
Stoich is stoich depending on the fuel u r using. Unless it's pure gas, it isn't 14.7:1. So the 450mv is a crossing point between rich/lean but it's not 14.7 necessarily. It more or less defines "no change". Here in the Midwest, we have "10%" ethanol, so I tune using 14.2-.3 for stoich in my cal. For WOT TUNING, I am using Lambda, not AFR. The only area I play w the O2 window is down at idle due to cams. Other than that, I leave the other values alone and concentrate on correct injector bias, prop gains, and VE.
I went with injectors with published constants.
adjusted prop gains also. (with a lot of help here)
I know I've run into numerous parts new off the shelf that were bad/shorted out.
Maybe I've just gotten bad O2 sensors?
#3799
The internal chemistry of a "narrow" band O2 sensor is such that it can only indicate two things.
1. Too rich.
2. Too lean.
The ideal stoich ratio varies somewhat with additives, somewhere between 14:1 and 15:1. Usually, pretty close to 14.65:1 or so. We typically round it to 14.7:1.
The O2 sensor indicates whether the burned exhaust came from a mix either too rich, ( generates roughly 0.9 volts ) or too lean. ( stops generating anything, ergo zero volts )
The chemistry is such that the response of the sensor is near instant. Averaged over time, ( 0.9 + 0.0 ) / 2 = 0.450
A narrow band will always indicate one or the other. Rich, or lean. Always.
The mix between the piston and cylinder wall above the top ring, for instance, never burns, ( because it is cooled below the combustion point by the heat extracted into both the piston, and into the cylinder wall ) but is blown out with the exhaust, so there is always some part of the exhaust that contains unburned fuel, and unburned O2. If even one molecule of O2 hits the sensor, it swings too lean. If even one molecule of unburned fuel hits the sensor element, it indicates too rich. There will always be a few molecules in the exhaust stream.
If, on average, the exhaust indicates too rich as often as it indicates too lean, we can presume that on average, the mix is close to stoich.
Another fortuitous reason for swinging between too rich and too lean, is so that the catalytic converter always has both fuel and air for IT to burn ! If a perfectly burned exhaust hit the cat, it would see only CO2 and water, and do nothing.
Ideally, we hit the cat with just enough unburned mix to keep it hot, so that it will do the final clean-up for emissions purposes.
The cat is only capable of a limited amount of burning. It is intended only to clean up and finish burn that mix that was caught between the piston top and cylinder wall. If it is overwhelmed, then the exhaust emissions go up. Late timing can cause some of the mix, even if it's correct, to not have burned before it blows through the cat, which then becomes partially overwhelmed, and show up as increased CO in the exhaust stream.
( partly because it's a catalytic reaction, not an actual "flame" burn )
That's why I suggest you advance timing a couple degrees, and look for a change.
Of course, it's also possible your cat is going, or gone.
#3800
Actually, if you are looking for stoich while using 10%, your WB would still indicate 14.7 unless you have function for adjusting the calibration curve. If not, then an AFR OF 14.7 would need to be a Lambda of 1 indicating an ACTUAL AFR of 14.2 or so.
