DIY WBO2 volts vs. AFR
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Anyone happen to know where the original DIY WBO2 volts vs. AFR can be found? I searched the web and can't find it. I seem to have lost the copy I had. I know this is not really DIY PROM, but I don't know where else to post this.
Thanks,
Junk
Thanks,
Junk
Car: check
Engine: check
Transmission: check
Code:
DIY WB Vout for Gasoline RR July 2001 Lambda values by MR Vout: Lambda: AFR: FAR: 1.40 0.685 10.08 0.099 1.45 0.695 10.23 0.098 1.50 0.706 10.38 0.096 1.55 0.716 10.53 0.095 1.60 0.727 10.69 0.094 1.65 0.738 10.86 0.092 1.70 0.750 11.03 0.091 1.75 0.761 11.20 0.089 1.80 0.774 11.38 0.088 1.85 0.787 11.57 0.086 1.90 0.800 11.76 0.085 1.95 0.813 11.96 0.084 2.00 0.827 12.17 0.082 2.05 0.842 12.38 0.081 2.10 0.857 12.60 0.079 2.15 0.872 12.83 0.078 2.20 0.889 13.07 0.077 2.25 0.905 13.31 0.075 2.30 0.923 13.57 0.074 2.35 0.941 13.84 0.072 2.40 0.959 14.11 0.071 2.45 0.979 14.40 0.069 2.50 1.00 14.70 0.068 * 2.55 1.037 15.25 0.066 2.60 1.077 15.84 0.063 2.65 1.121 16.48 0.061 2.70 1.168 17.18 0.058 2.75 1.219 17.93 0.056 2.80 1.276 18.76 0.053 2.85 1.337 19.66 0.051 2.90 1.405 20.66 0.048 . . . . . . 4.00 Free Air
