Exhaust leak - 02 sensor
Old 12-11-2007, 01:38 PM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
I have had an exhaust leak ever since I put my new headers in. I put in a new 350 at the same time, so I have had to tune it with the leak. I recently put new gaskets in, and the damn things still leak.
Anyway, my question is, how is this leak going to effect my tuning? Should I quit trying to tune it until I get the time to pull my headers again?
Thanks.
Old 12-11-2007, 03:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Exhaust leak - 02 sensor
As far as using the O2 sensor for tuning, no, can not use it with any exhaust leaks. Even a leak a foot or two down the pipe from the sensor.
Just a note, I have had to weld up header exhaust port flanges in order to get it to mate up with a gasket. It is something that one hates to even think about having to do. But once it is done it is worth it.
RBob.
Old 12-13-2007, 02:00 PM
Camaero's Avatar
Engine: 355
Damn. I thought as much.
Thanks for the help.
Old 12-13-2007, 02:57 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I will be doing this soon except the 350 but, what gaskets did you use and what headers do you have?
Let me know so I can prepare myself just in case.
Old 12-13-2007, 06:06 PM
91chevz71's Avatar
I'm gonna get my pipes welded after I change the tranny in a couple days. weld it all, make it permanent!!
Old 12-14-2007, 04:10 AM
Camaero's Avatar
Engine: 355
I am using Hooker headers. First I tried Summit Copper Gaskets. They leaked like a syph. I am now running Percy's Dead Soft Aluminum Gaskets. They are better, but still not sealing completely. I used stage 8 bolts the last time too, so it does not seem to be a matter of the bolts coming loose.
Anyway, good luck guys.
Old 12-14-2007, 09:09 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Well when I get mine Ill try Fel-Pro. See how they work.
P.S. My buddy is using his gaskets he got with the hookers and they sealed fine...but every motor/part is different.
Old 12-14-2007, 09:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Exactly my situation. The gaskets that came with the headers sealed. However, over time those gaskets became 'unavailable.' With the shape of the bead on the header to head flange, no other gasket would seal.
A round gasket would leak at a side, top or bottom (or a mix of). A square gasket would leak at a/the corner(s).
So I picked a gasket that I felt would continue to be available (IIRC, Mr. Gasker Ultra seal round), pulled the headers, welded up the bead on the ports where it would leak, filed bead flat, re-installed. No more leaks, and can use an off the shelf gasket instead of the manufactuers special now unavailable gasket.
RBob.
Old 12-14-2007, 10:05 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I see....Hmm, well, Ill be sure to let you all know when I get mine if I have problems....I hope not as I dont weld.
Old 12-14-2007, 12:53 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Would a good gasket and hi temp
RTV work
Old 12-14-2007, 03:12 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
RTV work
Kind of like putting the gasket on the flange and RTVing around the gasket?
Old 12-14-2007, 03:20 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
use the grey permatex. i've used it a couple of times and it works wonders.
Old 12-14-2007, 03:28 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Is that using it in the way I stated? Just in case....a little more seal never hurt.
Old 12-14-2007, 04:05 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
YES, it worked for me and lasted along time
Old 12-14-2007, 09:47 PM
r62mcmahon's Avatar
Car: 1989 IROC
i put the sealant on both sides of the gasket and bolted it up right away.
Old 12-14-2007, 11:31 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Take a good look at the gaskets and where the leak was before trying to fix it with sealant. It may be that there is minimal contact area and requires welding the exh. flange to get it to seal properly. Put a straight edge on the flange. I have fixed many exhaust leaks with a little welding and a file. All of which could have been fixed with sealant for only a short while.
bamaboy0323
09-03-2015 06:07 AM
TheExaminer
08-26-2015 04:59 PM
IROCThe5.7L
08-10-2015 11:24 AM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Exhaust leak - 02 sensor
