PCM hacking 101 - The step by step approach
#51
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Re: PCM hacking 101 - The step by step approach
ok damn, long read and what I got out of it is...... if I do an ls swap, I want you hacking my computer.
#52
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Old thread. Looks like these tools may be worth a try.
Disassembler:
Updated IRA
http://aminet.net/package/dev/asm/ira
Assembler:
VASM
http://sun.hasenbraten.de/vasm/
Disassembler:
Updated IRA
Assembler:
VASM
#53
Car: '82 Camaro
Engine: 355
Axle/Gears: 4th Gen 10 Bolt, 4.10
Thanks for posting those up junkcltr. Have you tried that disassembler yet? I've been looking for one as well to decompile a later green/blue connector pcm .bin file, but have had trouble locating a disassembly and can't splurge currently on IDA Pro.
#54
This is very difficult, I wish it was explained more? Why the need to pull the flash chip off the board? Can't you use a known good bin file? I have bins from the GM SPS, they are the same as what hpt uses, or efi live.
If I load these into ida I setup the Processor as moto 68330 there isn't a 68332, so is 68330 normal, there is lots of setting and options, no clue what to set them all for? am I creating ram or rom? I get a error message saying it doesn't know ere the start address of the code is? How do I find that, what exact settings do I input into IDA?
Also IRA, and dsm68 do not work just a black screen opens for half a sec, then tis gone?? Very frustrated!
#56
Here is a 99 vortec file 4.3L V6 automatic is this all I need to dissemble?
Looking at it in hex, Id guess 0x400 to be the start of the machine code, and 0x668co to be the end? But how do I implement this into IDA to read the disassembly?
#57
OK figured it out? press C at 0x04 and it starts decompiling, but I don't see any text to the right like you have, just move, push and numbers
Why don't I see anything like this construct idle rpm error, and all those actual numbers that make more sense?
; Construct idle RPM error term
LAB_2197:
CLR.L D3 ;Preclear D3
MOVE EXT_1460.W,D3 ;Load D3 with desired idle speed
LAB_2197:
#60
Ok I got Tos and St emulator running TTdigger, can figure out how to opne a file with ttdigger? Do I have to rename my bin file to .st, or .idx? I tired that, still cant seem to get it to work?
I get error stop and cant find OSVARS.RA whenever I try to to open anything with TTdigger?
#62
Car: 1983 G20 Chevy
Transmission: 4L60
I used Tunercats to segment swap a 4L80E transmission segment from a 2000 5.7 Experess van into a 2000 C1500 4.3 truck PCM that the owner had swapped a 4L80E into and tried to use the 4L60E tuning with a relay added to the system. Long story short it did not work out correctly with the relay, but worked well after the segment swap.
#63
Car: 1987 Corvette
Engine: Modified L98
Transmission: DN 4+3
Axle/Gears: 3.07
Sorry for the thread necropsy, but what an awesome thread.
Does a full assembly dump of any $6E bin exist?
A few years ago I went through a ABTB_HAC.SRC dump I have of a $32B to expand the TunerCat (and TunerPro) definition file for my '87 Corvette. I'd kind of like to look at maybe moving to $6E, but my car still has the Doug Nash 4+3 so I'd lose some functionality. I'm a bit curious if some of the same tables that control the OD on the transmission still exist in the 6E BINs even though they'd probably be purposed only for Automatics.
#64
Car: '88 Firebird
Engine: 305 TBI
Transmission: TH700R4
Axle/Gears: GM 3.23 TORSEN
There's 6E disassembly attached. Also, have a look at the XDF I did for 6E, it's quite complete, but it's missing some parameters in transmission section of calibration.
I remember that there were some strange manual trans parameters in hac, probably for 4+3 OD, but not defined clearly. If you add the 4+3 parameters, please share your findings.
#65
Car: 1987 Corvette
Axle/Gears: 3.07
Thank you! I don't know if I'll get around to it quickly, but will be sure to follow-up if I find anything interesting.
#66
Hello all fellow hackers I'm trying to find a 4.3L auto bin file for a 98 black box does anyone have one plz trying to tune my 97 but need a bin as my 98 black box has a 5.7 file on it know Thx
#68
Sorry to resurrect an old thread, but I'm hoping that @dimented24x7 or someone else can help me reverse a P59 OS (). I posted the text output of Ghidra disassembler at https://github.com/ColPaulR/GM-Gen-3..._4L60E.bin.txt. Looking at the vector table, INT3 appears to be the IRQ that is different than the rest. I assume that the MC68HC58 IRQ is tied to IRQ3. If so, the interrupt routine starts at 0x0005c4. Using the above and some comments from another commented disassembled OS at https://github.com/LegacyNsfw/125933....annotated.asm, I have been adding comments. Can anyone help me better understand what the code I'm calling void LVL3_FUNCTION(void) does? That is address space 0x0005C4 through RTE at 0x0006A0.
#69
ColPaul did you pm him directly about this or on http://www.gearhead-efi.com/ a guy LTR he is also very good at this
odddoylerules
06-01-2007 12:09 AM
