AXXF vs, AUJP spark advance tables - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 05-16-2010, 07:44 PM   #1
Car: 91 SLP GTA
Engine: Five Seven
I was looking at the differences between Bins today and decided to check out a 305 TPI's chip just to see if there was a difference so I looked at the AXXF bin which is for a 305/Auto car with speed density and TPI and compared it to a stock AUJP bin. I found that the VE tables were the same, but the AXXF bin had a much more aggressive spark advannce table than the AUJP for the 350 motors. Is there a reason why GM did this? I know that the LB9 and the L98 have the same compression ratio, and same camshaft specs in 91-92 but both used iron heads and both have the same fueling curve? Has anybody ever tried running the more aggressive SA table from the 305 on a 350 motor?
JekyllandHyde is offline vBGarage Page   Reply With Quote
Old 05-16-2010, 08:53 PM   #2
Car: 1985 IROC-Z28
Engine: LB9
Re: AXXF vs, AUJP spark advance tables
IIRC, a larger bore requires more advance for obvious reasons... and since the main difference between any 305 and 350 is the bore, that may explain the differences you saw.
Saar is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
89 Cranks... No Spark MM2Robinson Electronics 31 01-24-2016 09:59 AM
Carb rebuilt, still no start, stumped. No fuel? GeneralIesrussi Carburetors 3 10-30-2015 03:36 PM
Cam Question Jorlain Tech / General Engine 6 10-08-2015 02:57 AM
Engine won't start no spark at the plugs Jlanz55 Tech / General Engine 3 09-09-2015 10:09 AM
Timing Chain Changed, Car Won't Start db057 TBI 8 09-06-2015 09:11 AM
Go Back   Third Generation F-Body Message Boards >
Tags
350, advance, aujp, aujpbin, axxf, bin, chevy, chip, compression, gm, prom, ratio, spark, table, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
