tcc question
Car: check
Engine: check
Transmission: check
Re: tcc question
I don't know of any ECMs/Masks that required closed loop for TCC lockup. Is the ECM not commanding lockup?
Which mask are you working with?
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Re: tcc question
Looked through the $8D mask firmware and show nothing that would cause the TCC not to lock when the ECM is in open loop. So... slapped a '7730 on the bench and blew in the ANHT BIN ('90 Corvette auto).
TCC locks up before the ECM goes into closed loop.
Blew in AUJP ('90 - '92 Camaro/Firebird) and the same thing. TCC would lock up before the ECM goes into closed loop.
Edited an ANHT BIN by setting the closed loop enable temperature high. ECM never goes into closed loop and the TCC works as it should.
RBob.
RBob.
Ok thanks. That was my suspicion as well...now congirmed. Now to find out why the damned thing wont work. My red brick scanner only shows p1 or p2 whatever that is. P-N. and -R-D321 indicate correctly. The brake pedal switxh works and I have 12v. Also the press switch setting in bin is correct.
Re: tcc question
Well, it's still not working. I hooked the scanner up, 4th gear switch status changes just fine (p1 in 1-3 P2 in 4th), speed signal works w/ 8K pulse and vehicle speed in stream reads correctly. Still commanded lockup remains in P1, it will not lock up. I think it might require closed loop afterall. Using $8d on a 1227727 weatherpack ECU. Brake switch operates fine. The ECU simply does not command lockup,.
Car: check
Engine: check
Transmission: check
Re: tcc question
I was wondering which BCC you started with. Looking at AXCN, a 6-spd y-body BIN, doesn't have most of the TCC parameters/tables populated.
With this flag having to be cleared:
Code:
L8018: FCB $D4 ; AFR OPT WD 3, 1101 0100 ; ; b2, 1 = CPU Auto Ratio Sel, 0 = TCC
Re: tcc question
I got it to work by setting the unlock prevention to 45mph just to test and sure enough it commands P2 and locks up just fine. I'm going to set this to 255 because it's bloody annoying that it won't release and you loose TQ multiplication. So...something is keeping the routine from locking (or better yet, telling it to unlock the TCC) gotta figure out what, I started w/ a 92 GTA bin, it has the proper 4th gear switch NO setting, the vette has it reversed. I took the TCC tables from the vette however.
Re: tcc question
Well...got it working YAY!! Turns out the prom that came in the system was some kind of hacked up manual prom set to work on an auto and possibly without tcc. One of the undefined bits must have been the issue. Started with a 91 vette a4 2.73axle prom since that matches the peg leg granny rear in my truck (wouldn't want it shroter, the damned thing is twitchy as hell as it is and blasting the autobahn at over 140mph sure is fun.. people staring because of a lame old truck passing them at speed LOL)
Now to tweak the lockup a bit so it disengages with less throttle..right now it tranitions violently because it's set around 25% throttle, which in my case is tire spinning levels
Thanks especially to you rbob
Re: tcc question
I'm having a similar problem since I swapped to a 3:54 rear. TCC lockup is no longer working. Just started researching today, hopefully I'll find the issue. EBL still has the same tune as it had when running the 2.87 rear. Any help as always is appreciated, TCC locked fine before the swap, all we did in the trans was install the correct gear to drive the speedo and did a trans fluid and filter change while we were in there. Old fluid was fine, still red, didn't smell burnt, not discolored, no unwanted metal or trash in the fluid.
Car: check
Engine: check
Transmission: check
Re: tcc question
Probably knocked the wires or connector loose at the trans. Try this, key-on, engine-off and measure the voltage on pin F of the ALDL connector.
Should be +12 volts. If so then ground pin F and listen for the TCC solenoid to click. If it does then the ECM should also cause it to lock up.
Note: not knowing which actual vehicle and MY it is, ALDL pin F may or may not be the TCC lock signal from the ECM.
RBob.
RBob.
