Pretty accurate mpg calculator
Not sure if this has been attempted before...
But I generated a mpg calculator using the injector pulse width from the scanner readout, along with vehicle speed and engine rpm. Actually fairly simple math with a bunch of unit conversions.
But it's very accurate compared to the results I get with the standard approach of measuring mpg. I measured ~23 mpg, the calculator says I'm getting 23.49.
I've attached it in the zip file. It needs Excel 2007 or higher to run though.
1 Post
Car: 1985 IROC-Z28
Engine: LB9
Re: Pretty accurate mpg calculator
i was hoping you had cracked out an equation that would generate an accurate trip MPG..... the equations i come up with seem to work great for instant MPG calcs, but i've never gotten one to create an accurate trip value, always have significant error in either direction depending on the equation.
You'd simply add and formula-rize a column that looked at injector pulse width, engine rpm and vehicle speed. It would calculate an instantaneous mpg at each sample.
Then at the end of the data set, you'd run a mathematical average of all the mpg calcs for a trip average.
Send me a tunerpro .csv output file and I'll generate one.
Yeah for the spreadsheet I originally posted. I used an injector pulse width that corresponded to cruising at 65 mph constant speed on flat ground. Agreed it will not account for variability with acceleration.
1 Post
Car: 1985 IROC-Z28
Engine: LB9
i worked out my own solution a while ago..... but it's a lot more involved than math on just the PC side of things. i was just more interested to see if someone could get an accurate trip value from the existing items sent over the datastream since mine were never quite correct.....
i had to cheat a bit and create some 16-bit accumulator values in the ECM's RAM that figure out distance and fuel used this ignition cycle, then spit that out to the PC to do the final math and keep track of trip distance and fuel used(since i could otherwise have done that division on the ECM side as well and only output 1 16-bit value).
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I tried doing calcs somewhat like this in TunerPro 4.x. I wanted to have one "pseudo" ALDL value that was made up of other real ALDL values. As an example, suppose you want to report MPG. That is a function of (BPW, RPM, Time, VSS). All of which the ECM reports. Granted that the BPW will have to be assumed to be constant over the Time period which it really isn't. It will give an averaging affect.
Does TP 5.x support mult-ALDL variable equations? I couldn't do it TP 4.x from memory.
MPG(INJ_BPW, RPM, ECM_TIME, VSS)
Car: check
Engine: check
Transmission: check
They are roll over counters, 8-bit for the VSS pulses and 16-bit for the injector pulses.
RBob.
1 Post
Car: 1985 IROC-Z28
Engine: LB9
Check out the $8D mask, it has VSS and injector PW accumulators in the ALDL stream. GM used this info for the trip computer (DIC). Easy to take a look and see how the data was collected on the ECM side.
RBob.
RBob.
mine isn't finalized since i never implimented it, just tested the code out to make sure that it works how i was expecting it to(1 mile increments after being held at 60MPH for 60 seconds, etc). now that i look at my code more.... there is at least one change i think i'm going to make since it currently does math based on how much a single injector has flowed. with a 20 gallon maximum value, it would take a multi-port engine a lot longer for increments to happen than what i was planning. a 6 injector engine would now actually be a 120 gallon max value, 8 injectors with 160 gallons..... cuts down on my fuel use resolution pretty significantly.
Car: Too many to list...
What do you plug in for injector pulse width? Plugged in 65 lb/hr for injector flow from my setup, not sure about pulse width though
7427 swapped TBI
7427 swapped TBI
It's the duty cycle.
For example, I got on an open stretch of road and got to steady state cruising speed, then noted the injector duty cycle on the scanner. Should be in milliseconds.
Figured it would be a good representative value for average highway fuel economy.
So you just note your injector base pulse width on the dash in TunerPro and plug that value in to the spreadsheet, correct???
Very cool, thank you for sharing this.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Yes, it does. And you can create statics by creating an ADX Value with the static value as the equation (e.g. "25.8"), then reference that static value in the equation of other ADX Values.
rb85TA
26
09-14-2015 10:29 PM
