A/D Temp Table
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
A/D Temp Table
Somehow I changed the temp to enable CL and I was stuck in OL all the time. I went back in my .bin history and found what it should be and changed it. However in the .xdf I am using for TunerPro it says to reference the a/d temp table for values to enter for the Closed Loop Temperature. Does anyone know where to find this so I have it for the future.
Car: check
Engine: check
Transmission: check
Re: A/D Temp Table
TBI with the '8063 ECM? Use the first two columns.
RBob.
Code:
;* A/D degrees A/D ;* counts C Inv ;* ------- ------- --- ;* 255 -40 0 ;* 251 -30 4 ;* 250 -25 5 ;* 247 -20 8 ;* 245 -15 10 ;* 241 -10 14 ;* 237 - 5 18 ;* 231 0 24 ;* 225 5 30 ;* 218 10 37 ;* 209 15 46 ;* 199 20 56 ;* 189 25 66 ;* 177 30 78 ;* 165 35 90 ;* 152 40 103 ;* 139 45 116 ;* 126 50 129 ;* 114 55 141 ;* 102 60 153 ;* 92 65 163 ;* 81 70 174 ;* 72 75 183 ;* 64 80 191 ;* 56 85 199 ;* 50 90 205 ;* 44 95 211 ;* 39 100 216 ;* 34 105 221 ;* 30 110 225 ;* 26 115 229 ;* 23 120 232 ;* 21 125 234 ;* 18 130 237 ;* 16 135 239 ;* 14 140 241 ;* 13 145 242 ;* 12 150 243 ;* 0 200 255
Engine: 327
Re: A/D Temp Table
TBI yes, but I have an 8746 ECM. Not sure what's going on. I had it set at 26 and previously it was 128. So I had it set around 115C instead of 50C. I know I had been doing some tuning that required keeping it in closed loop but I only get to the car once or twice a year. A lot can be forgotten in 3-4 months as far as this slow EPROM stuff goes.
Thanks for the help. Is this availible anywhere I can print it off and keep it in my TBI ECM files?
Re: A/D Temp Table
RBob.
Code:
