EBL Settings For No TCC/Manual Valvebody?
Old 10-23-2014, 11:50 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
So let me clarify real quick that I DO have TCC lock-up. The thing about it though is I have the Trans-go 2&3 kit setup with the stick only option (Full manual valvebody). The TCC lockup wiring in my valvebody is the type that relies off governor pressure to ground the circuit out and lock the TCC. The stick only option of the transgo kit places a spring clip on the governor, commanding full governor pressure 24/7. Because of this, my TCC would remain constantly locked.
As a remedy, I used 4 SPDT relays to create a latching on/off relay cluster toggled by a momentary push button on my shifter handle. In short, the ground for the TCC lockup relay never makes it back to the ECM, so the ECM has no control over lock-up and I manually lock/unlock the TCC myself.
I am thinking it might be a good idea to disable TCC lock-up altogether in the tune since it would be possible for the EBL to command a lock-up, thinking it is locked when it really isn't?
Also, are there any other options or parameters I should configure for having a manual valvebody? I have verified in the WUD that the EBL is able to differentiate between D (1-2-3) and OD (4th).
Old 10-24-2014, 08:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Settings For No TCC/Manual Valvebody?
Just set the enable temperature high (150* C):
TCC - Lock Enable CTS
That will prevent the ECM from commanding the TCC to lock.
RBob.
Old 10-24-2014, 12:45 PM
Car: 1985 Z28
RBob.
Thanks Rob, as always! Slowly getting the hang of this elaborate contraption
1992Vortec
08-31-2015 08:05 PM
hydrolic144
08-29-2015 04:14 PM
soarestransam
08-24-2015 08:15 AM
mustangdmurder
08-21-2015 07:17 PM
beast94
08-20-2015 06:44 AM
Quick Reply: EBL Settings For No TCC/Manual Valvebody?
